Idle jump 2021 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ayusuf99, Oct 4, 2021.
  1. Oct 4, 2021 at 7:30 PM
    Ayusuf99
    Ayusuf99 [OP] Well-Known Member
    Ali
    2021 green tacoma trd off-road
    Stock
    I have a 2021 Tacoma. and the idle only jumps when the heat or ac is on and it goes from 600 to 900 is that normal
  2. Oct 4, 2021 at 7:31 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    When AC is on yes.
    Skydvrr likes this.
  3. Oct 4, 2021 at 7:34 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    It also does it when you're steering without touching the gas. Basically the engine needs just a little more power to run those things effectively so it bumps it for you. It's not unique to Toyota.
    Chew and Skydvrr like this.
  4. Oct 4, 2021 at 7:36 PM
    Ayusuf99
    Ali
    Stock
    Basically the only jumps when idling when the blower for the Heat and or air is on
  5. Oct 4, 2021 at 7:40 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yes. Any additional load is compensated by the ECU. Imo of course.
    Chew likes this.
  6. Oct 4, 2021 at 7:44 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I had a Samurai that had a vacuum pot on the side of the carb. When I turned on the headlamps, the rpm would bump up a bit. This is completely normal with most vehicles.
    RedWings44 likes this.
  7. Oct 4, 2021 at 7:52 PM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Concur.
  8. Oct 4, 2021 at 7:54 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Just idling up to give you the juice needed
  9. Oct 4, 2021 at 7:54 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Additional load = additional power. Not hard math.
    Chew likes this.
  10. Oct 4, 2021 at 8:01 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    You’re putting a bigger load on the engine when you use additional accessories such as ac. Normal
  11. Oct 5, 2021 at 4:02 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Take it to the dealer.
