Idle Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Street, Aug 23, 2011.
  1. Aug 23, 2011 at 5:21 AM
    Street
    Street [OP] Well-Known Member
    jon
    Brevard
    Tacoma
    Hi, My truck is a 99 2wd reg 2.4 or (2rz?) my idle shifts high and low at red lights etc... mainly when the A/C is on and you can sometimes here the relays flipping out.
    things I've done
    IAC cleaned
    temp senor
    plugs wires
    new bat.
    The truck now has 307k and I got her for 750 with 296k the miles are all highway and mostly what I put on. I went over a little bit on the oil change I just did and the oil was cleaner that any motor I have ever done. SOLD on Toyota!!!!!!
    So any help? thx Jon Street
  2. Aug 23, 2011 at 6:34 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Is your truck a manual? Does it just idle surge when putting your foot on the clutch when slowing down? If so, mine did that and I replaced the TPS and problem solved.
  3. Aug 25, 2011 at 8:13 PM
    Street
    jon
    Brevard
    Tacoma
    na never noticed that as a problem and i don't really have a cold start prob either, just got an idle drop and increase when the ac cycles
  4. Aug 26, 2011 at 10:01 AM
    96Taco
    Alberta
    '04 V8 4Runner
    ..stay tuned
    thats normal.
  5. Aug 27, 2011 at 4:21 AM
    Street
    jon
    Brevard
    Tacoma
    its not come drive my truck....if Toyota could think for a min. a 5spd truck or car would be better with a Tech.
    My idle is not a little drop and increase its a damn spike that can sometimes cause it to die but not often:confused:
  6. Aug 27, 2011 at 4:58 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    When's the last time the injectors were cleaner? Fuel filter changed? MAF cleaned?
    If you want to rule the AC out, just unplug the clutch.
  7. Aug 28, 2011 at 2:52 PM
    Street
    jon
    Brevard
    Tacoma
    I ll do that...the fuel system gets Lucas and I did the fuel filter around 5k ago
  8. Aug 28, 2011 at 11:19 PM
    Street
    jon
    Brevard
    Tacoma
    I'm telling you its not I don't know much about tacoma's but I'm 100% on the fact that my idle spike is not what came from the factory...I'll go buy a Tech on Monday and i'll report the rpm's after 10pm:cool:
