Idle Problems!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruizbau2699, Oct 24, 2017.
  1. Oct 24, 2017 at 3:18 PM
    Ruizbau2699
    Ruizbau2699 [OP] Well-Known Member
    Noe
    Easley South Carolina
    2018+1999 Tacoma TRD OFF-ROAD
    Hey guys i need help my truck tends to idle very high at the crank like at 2000 rpms and once it’s warmed up it still idles at 1000 rpms and sometimes out of nowhere it’ll idle up and down for 1000 to 2000 or 2500 rpms countinuasly until in gear off the clutch is there an idle adjuster or is it something else going on???
  2. Oct 24, 2017 at 3:28 PM
    eon_blue
    Azusa, CA
  3. Oct 24, 2017 at 3:29 PM
    eon_blue
    Azusa, CA
    BTW you accidentally posted this in the marketplace section, lol. Maybe a mod can move it for you @tcBob
    edit: that was fast
    T-Rex266 likes this.
  4. Oct 24, 2017 at 3:34 PM
    Madjik_Man
    Colorado Front Range
    Sounds like a throttle position sensor is wonky.
    I've had to replace two in my truck's lifetime with the same symptoms.
  5. Oct 24, 2017 at 3:36 PM
    Ruizbau2699
    Noe
    lol yeah I was trying to fix it the moment I posted it and yeah i kinda figured that’s what it was but i wasn’t sure thanks! Do you happen to know where on the3.4l is it located
    eon_blue[QUOTED] likes this.
  6. Oct 24, 2017 at 3:38 PM
    eon_blue
    Azusa, CA
    @sean266 already moved it to the right forum for ya
    edit: sorry, thought you were talking about the right forum...the IAC is below the TB like @Madjik_Man said
  7. Oct 24, 2017 at 3:38 PM
    Madjik_Man
    The IAC is located below the throttle body.
  8. Oct 24, 2017 at 4:22 PM
    Godzilla619
    Godzilla619 Well-Known Member
    David
    San Diego
    2000 Black Taco prerunner v6
    Mid travel
    I had the same probs with mine, changed the MAF, cleaned the IAC, and bought a new coolant temp sensor. Fixed the problem.
