Idle rpm increase while in Drive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brokenfoot, Jun 10, 2025.
  1. Jun 10, 2025 at 5:36 AM
    Brokenfoot
    Brokenfoot [OP] New Member
    Dave
    2021 Tacoma SR5 4wd V6 access cab
    none
    I'm an old, retired guy with a recently purchased 2021 SR5 4wd, 6cyl access cab Tacoma with 21K miles, I live in Minnesota.
    I have a very tight spot to park in, at idle creeping into my spot I get an unpredictable Un commanded idle increase of about 5 to 7 rpm making parking a challenge.
    Truck operates normal, no fault lights and operates normal while driving.
    The rise in RPM is proceeded by a solenoid click that I'm guessing is the Idle Air Control Valve. The command to that solenoid I'm guessing comes from the Engine Control Unit which maybe senses a low idle. I don't think I can raise the idle with an adjustment.
    Anyone have ideas of what the problem could be or how to trouble shoot.
    The dealership told me without a fault light their must not be a problem. ha ha
  2. Jun 10, 2025 at 5:38 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Turn your air off or windshield defogger vents off.
  3. Jun 10, 2025 at 6:05 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Also turning your steering wheel will do the same thing.
    fdbyrne, BillF1564, t0p_d0g and 2 others like this.
  4. Jun 10, 2025 at 6:08 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Welcome to TW and to owning a very smart truck...
    It is normal, and no mechanical adjustments for the idle, it also does not have an idle control valve as it is what is called a drive by wire, it has an electronic throttle actuated controlled throttle body...
    You would never feel a 5-7 rpm idle chance, did you mean a 500 - 700rpm surge?? If I understand your concern correctly, what is happening is normal for these trucks, what you are feeling is either the A/C cycling causing the ECM to command a higher idle (as mentioned the A/C runs when in defrost mode) and or the strain on the engine when turning the steering wheel also causing the ECM to command an idle increase...
    You could also have a dirty throttle body and the ECM is trying to compensate for it... You can look at live data to see the idle %...
    t0p_d0g and Chew like this.
  5. Jun 10, 2025 at 6:35 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Lots of opinions here so I’m throwing mine in I think what you are feeling is the well known Tacoma lurch and I think a TSB was issued for this problem although it might not have been for the 2021 model but it’s worth contacting your local dealer about it. IMO
    kahanabob and DavesSR5 like this.
  6. Jun 10, 2025 at 12:54 PM
    Brokenfoot
    Dave
    none
    Thank you everyone for the replies.
    t0p_d0g and DavesSR5 like this.
