Idle rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 57chevylt1, Aug 7, 2017.
  1. Aug 7, 2017 at 11:52 AM
    57chevylt1
    57chevylt1 [OP] Member
    Jim
    15 Tacoma double cab
    None
    Question and can't seem to find a solution. I have 2015 4x4 double cab short bed 6 cylinder, 22K. Great truck and very happy except. The truck idled at 1100+ rpm. I put in gear and drops then to 800+-
    Any way to get the idle in park or coming to a stop to go to the normal 800 rpm as all previous toyotas/Lexus vehicles I've owned did? Anyone able to help solve this. Thanks
  2. Aug 7, 2017 at 12:21 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Is it fully warmed up?
    Mine fully warmed in gear will idle as low as 500rpm, a/c will jump it up to 700.
  3. Aug 7, 2017 at 12:38 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup make sure its fully warm. Yours sounds like cold idle rpms there.
    specter208 likes this.
  4. Aug 7, 2017 at 12:52 PM
    57chevylt1
    Jim
    None
    Yes, fully warm. It's 1500+ when cold. Dealer says normal but seems way high!
  5. Aug 7, 2017 at 2:47 PM
    nd4spdbh
    SoCal
    hmm Ill check my truck once warm in and out of gear when i get home for ya
  6. Aug 7, 2017 at 4:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When fully warm it should idle at 700 RPM.
    Check for a small leak on a vacuum line... or intake.
  7. Aug 7, 2017 at 4:07 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I noticed when i switched from 87 to 93 octane fuel, it seemed like the idle rpms were much smoother when in neutral without the ac on. I could just be crazy, but i also have the 4cyl and it seems to idle more smoothly with higher octane as well.. just a thought?
    Another thing it might be is if youve unplugged the battery recently, it might have to relearn the fuel maps and other things before it smooths out.. hoping youve unplugged the battery recently.. otherwise sorry if this post was of no help..
  8. Aug 7, 2017 at 6:18 PM
    nd4spdbh
    SoCal
    750rpms out of gear (auto) 650 in gear without AC running.
  9. Mar 27, 2018 at 6:58 PM
    BlackCat45
    BlackCat45 Member
    San Bernardino, CA
    2009 Silver Tacoma Prerunner V6
    All stock
    I've got an obd II scan tool that gives a digital reading for the rpms. My truck idles between 612-617 rpm when warm, about 1200 rpm for a couple of minutes when it's cold and I just started the truck, and between 700-730 rmp when warm and put into park. I also notice when the A/C is on, the rpms jump up around 60 rpm for a few seconds, then idle drops back to normal, than about 5 seconds later the rpms jump up around 60 again, over and over, like it goes through a cycle or something to power the A/C.
  10. Mar 27, 2018 at 7:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    All vehicles with AC do this "idle up".
  11. Mar 18, 2020 at 11:22 AM
    Diego Fuentes
    Diego Fuentes New Member
    Diego
    1997 Toyota tacoma 4x4
    I just baught my 1997 Toyota tacoma 4x4 sunday the 15th and it was idling at 1250 till this morning the 18th on my way to work my truck died an when I able to start it back up the idle was at 750 an has stayed there. Could it had happened from putting in a new battery or what could it be?
