Idle Shake
Discussion in '4 Cylinder' started by epa4wd, Apr 9, 2009.
  1. Apr 9, 2009 at 5:17 PM
    epa4wd
    epa4wd [OP] Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    I've noticed that my Tacoma shakes at idle when its in Drive, it usually happens when I'm in a stoplight, after a few seconds the truck starts shaking you can feel it trough the leg and the seat and it goes away when shifting to Neutral. The truck only has 340 miles, I will obviously take it to the dealer for warranty, but I want to know first if someone else has experienced this problem and what was done to fix it. :confused:
    Truck
    09. Reg Cab, A/T, 2.7L
  2. Apr 10, 2009 at 4:50 AM
    olehipi
    olehipi Member
    Pensacola,FL
    taco negro
    I had this problem on an '85 Tercel and it turned out to be a disconnected vacuum line.
  3. Apr 10, 2009 at 6:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Depending on how bad the shacking is, yes. The sencond gen trucks with autos have a lower idle speed when in gear than the previous models, so some shaking can be expected.
  4. Apr 10, 2009 at 7:19 AM
    epa4wd
    Eduardo
    2015 TRD Sport
    The shake is not extreme, but enough to make it annoying. I will check the vacuum lines, but Im not sure if the shake is from the engine or from somewhere else.
  5. Apr 10, 2009 at 9:35 AM
    epa4wd
    Eduardo
    2015 TRD Sport
    Took it for a ride today, I think I'm just being to picky, I think is like you said about the lower idle speed, because it doesn't do it with the A/C on only with the A/C off since the rpm tend to be a bit lower with A/C off. I will ask once I take it for maintenance just to be sure, but otherwise I think this is normal.
    Maybe I'm just looking for excuses to ride around more with it :)
  6. Apr 10, 2009 at 9:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sounds like its normal.
  7. Apr 10, 2009 at 9:43 AM
    alankidwell
    alankidwell Member
    07 4 cyl access cab
    We have a few 07 2.7 reg cab autos at work, and they shake like you describe. But i have an 07 2.7 access cab auto and it does not shake at all. i wonder what is different.
  8. Apr 30, 2009 at 6:16 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    4 cylinder engines are naturally unbalanced. This is my second Toyota, and I have noticed their 4 cyls vibrate more than say a Honda. The price you pay to actually have some torque. Annoying yes, a problem, not likely.....
  9. Apr 30, 2009 at 7:09 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    Not to mention our 4 bangers are 2.7 LITERS, they will have their own particular harmonic. Balance shafts, engine mounts, and harmonic balancers can only remove so much of the vibration. It's still a really smooth running engine for it's size.
  10. Apr 30, 2009 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its very smooth for a large 4 banger. It has twin ballance shafts, and, all in all, I think Toyota did good with it.
  11. May 1, 2009 at 6:33 AM
    sweater914
    North Dakota
    Toyota did a great job with the engine, the domestics could learn a thing or two from Honda and Toyota when building their 4 bangers. I've driven Ford products, '98 escort, '99 ranger, '00 focus with displacements of 2.0-2.5L and all were thrashy engines, they work well but not very polished especially in the upper rpm ranges. I just picked up an '05 civic with the 1.7L mill and it's a night and day difference, comparing the honda to the ford sedans. I can see why ford lost their ass in the econo box price range, the same 1.7L in the '05 was first used in '01.
  12. May 1, 2009 at 6:43 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    I think you are being picky too. Any 4cyl I have had shook at idle. Even more so when in gear since you are putting a load on it and the backside of that load is everything connected to the motor, so you are going to feel it a bit.
    I'd say its normal. Even my 4.0 shakes a little bit.
    Its a brand new truck. Probably nothing wrong with it.
  13. Jul 11, 2009 at 8:23 AM
    RichP
    RichP Dedicated Toyota Buyer
    Tacoma, WA
    '10 Tacoma Access Cab SR5
    I'm having this same issue with my '97 2.4L automatic with 103k miles - it idles fine when cold, but when warm the shake develops about 5 seconds after coming to a stop & it goes away when shifting to neutral.
    The truck does not have a/c so it's not a compressor cycling issue.
    I've checked the vacuum lines and they all seem good so I'm looking for guidance on where to look next. Thanks for your help!
  14. Jul 11, 2009 at 8:48 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    mine doesnt flinch or shake even the slightest. used to a little bit with the ac on and idle it would jump up to 1100 rpm and the fan made it shake but then i changed my cabin air filter and idle with the ac stays at 700 rpm and no shaking or trembling at all.
  15. Jul 12, 2009 at 11:15 PM
    u02913
    u02913 Member
    pa
    1996 tacoma
    I have a 1996 Toyota Tacoma that shakes when idling at a stop,but when I turn on the AC with the fan on the shaking goes away. Could my minimum idle speed be set to low,and if so how can I speed it up slightly? I had it checked twice buy the dealer and he said everything is in spec and I should just live with it, I had all new engine mounts installed but there was no difference. Thank you.
  16. Jul 17, 2009 at 6:17 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    that happend to me i was waiting for a train to pass the road felt a weird shake got out a vacum line came loose grabed a vip tie out of the truck stuck it back on good to go.
  17. Jul 17, 2009 at 6:20 PM
    08pretaco
    Oliver
    az
    damn haha it came back. it goes away when the clutch is engaged though!?
