Idle speed warm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNavyTaco, Mar 22, 2011.
  1. Mar 22, 2011 at 2:47 PM
    USNavyTaco
    USNavyTaco [OP] Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    Does this sound right?
    Engine: Warm
    In park: 750
    In drive, AC on: 750
    In drive, AC OFF: **500-550
    This is what concerns me. The 500ish idles. No roughness, no shake, just 500?
  2. Mar 22, 2011 at 2:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Normal.
  3. Mar 22, 2011 at 2:57 PM
    USNavyTaco
    Goose Creek SC
    Wonderful. I was just wondering. Cause I used to have a vue that would drop to about 450 without AC on when it was in drive. It would then stall. I was just scared that this car was beginning to do the same thing.
  4. Mar 23, 2011 at 8:11 PM
    USNavyTaco
    Goose Creek SC
    So what would abnormally low be for a tacoma's idle in gear?
  5. Mar 23, 2011 at 8:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Below 500 RPM.
  6. Mar 23, 2011 at 8:29 PM
    USNavyTaco
    Goose Creek SC
    Haha that makes sense. Thanks. Ill stop looking at it. I'm just getting paranoid. As I am with everything my truck does, guess it's cause I'm used to driving general motors and dodges.
  7. Mar 23, 2011 at 9:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I wouldnt sweat it. The V6 regularly idles around 550 when warm. It wont go much lower at all. the lowest I have seen on my UG is 549..
  8. Mar 23, 2011 at 9:48 PM
    USNavyTaco
    Goose Creek SC
    Thanks a lot.
  9. Mar 24, 2011 at 8:43 PM
    USNavyTaco
    Goose Creek SC
    Just for future reference, and because im trying to do more of the simple work on my truck myself, What situation would warrant an IAC valve and throttle body cleaning? When the RPM's become low enough that the engine struggles, or when the RPM's do not raise back up when I put the truck into park or neutral?
  10. Mar 24, 2011 at 8:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you replace your filter when required, you shouldnt have any IAC issues. AS for the TB, I wouldnt worry about that until near 100k miles.
  11. Mar 24, 2011 at 9:04 PM
    USNavyTaco
    Goose Creek SC
    Good to know. I will be replacing my air filter this summer with a k&n air filter
  12. Mar 24, 2011 at 9:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In that case, plan on cleaning the TB more often. The OEM filter flows very well, and you wont get anything from the K&N other than a washable filter, and oil build up on the TB and other intake components.
  13. Mar 24, 2011 at 9:22 PM
    USNavyTaco
    Goose Creek SC
    O. Well then. Guessing a k@n would not be the best option for a "set it and forget it " approach. Hmmm.
  14. Mar 25, 2011 at 6:59 PM
    USNavyTaco
    Goose Creek SC
    Interesting. New tidbit here. When coasting in idle, every now and then I get a chirp up in idle speed, jumps about 50-100 rpm, then back down. No shake, no speed increase. Any ideas?
  15. Mar 25, 2011 at 7:14 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    tranny downshifts
  16. Mar 25, 2011 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AC/Defroster, and the PS pump have idle up controls. It could be one of those. Or, Simply the engine managment comp doing its thing.
  17. Mar 25, 2011 at 7:19 PM
    USNavyTaco
    Goose Creek SC
    ah. That would explain it. Yea. Sorry for all these posts. As I said before in the thread, I'm coming off a 03 Saturn vue, (cvt), this is the first "real" transmission vehicle i have driven.
  18. Mar 25, 2011 at 7:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont be coasting in neutral often with the truck. It can cause the tranny to over heat. And RPM fluctuations of 100 rpm or so are normal.
  19. Mar 25, 2011 at 7:35 PM
    USNavyTaco
    Goose Creek SC
    I meant coasting in gear( drive) not neutral, sorry for not being specific. But sadly I'm not used to transmissions with gears at all, freaked me out when I put the truck from drive into reverse there is that "clunk", not used to that at all, Cvts don't clunk, but they fail every 40 thousand miles, haha
  20. Mar 25, 2011 at 7:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In that case, it may have been the tranny downshifting, like supralight said.
