Idle surgs when brake pedal is pressed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Falkor1, Apr 10, 2019.
  1. Apr 10, 2019 at 9:37 PM
    Falkor1
    Falkor1 [OP] Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    My friends 1988 22re pickup is surging when you press the brake pedal. I know this isn’t a Tacoma but does anyone have any advice on what’s going on? Is it the brake booster, master cylinder, or both? Here is a video of what’s going on.
    When I plug the vacuum line going to the brake booster the idle surges, but when I unplug it the engine runs rough but stops the idle surging.
    https://youtu.be/0RcXOHAfh44
  2. Apr 10, 2019 at 9:39 PM
    Falkor1
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    Could there be a blockage in the booster to cause this?
  3. Apr 10, 2019 at 10:55 PM
    Falkor1
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    Never mind it was the timing and the idle. Sorry for the extra post.
  4. Apr 11, 2019 at 12:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    At least you figured it out
  5. Apr 11, 2019 at 8:53 AM
    Glamisman
    Glamisman Well-Known Member
    there still could be a bad booster. With the motor off how many brake pedal applications do you get before the pedal get hard. 1 to 2 applications is normal. If the pedal is rock hard immediatly after the motor is off either the check valve, if it has one, is bad or the booster has a crack in it.
