Idle too high in park, on cruise intermediate misses
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rocket86, Jan 28, 2024.
  1. Jan 28, 2024 at 6:43 PM
    Rocket86
    Rocket86 [OP] Well-Known Member
    2002 Ext Cab 4x4 TRD 3.4 auto 190,000 1 owner, All records from Toy Dealer from new. Replaced all fluids,plugs, Spk plug wires,All OEM. Synthetic. Me- 56 yrs old
    Ran perfectly for 5000. Chk Eng light off and on. Idle too high in Pk. On cruise intermediate misses, almost like it’s starving for fuel/oxygen. I am sure it’s minor. Thank you very much.
  2. Jan 28, 2024 at 6:51 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Need OBD2 code
    Then can point u in ‘a’ direction
    TACOTU3 and TnShooter like this.
  3. Jan 28, 2024 at 11:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When the check engine light gets turned on, the truck's computer will store a code that will give details about the reason if was triggered. As mentioned, an OBDII reader can read (and clear) any stored CEL codes in the ECU. If you don't have access to a code reader like this, local auto parts stores like Autozone or O'Rielly's have a tool they can plug into the ODBII port on your truck to read the code(s). This is a free service.
    If we know what the code that triggered your CEL is, we can give you advice on what is wrong and what you'll have to do to fix it.
  4. Jan 30, 2024 at 8:10 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    not all performance issues throw codes. the idle is always higher in park around 700. and does the miss happen only when in cruise control or at a steady highway speed?
