Idle water temp & fluctuations
Discussion in '1st Gen. Tacomas (1995-2004)' started by betterbuckleup, Jan 4, 2019.
  1. Jan 4, 2019 at 11:55 PM
    betterbuckleup
    betterbuckleup [OP] Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    For those that have a scan gauge and monitor engine water temps, what is the highest temp you see at idle?
    I recently changed my water pump and temps were spiking to 210F at most when idling in place after I changed it. When driving around, it was much more reasonable at around 184-188 (which is where it has been consistently in the past).
    I figured this was because my fan clutch fluid coupler was bad which is why my idle temps were so high (fan not fully engaging to pass more air). I figured this by testing how easy it was to rotate the fan by hand when it was both cold and warmed up.
    Although after changing the fan clutch, I am still seeing max idle water temps of around 200F or so after up to temp.
    Are these temps safe/normal for a 3rz engine? They have never fluctuated as much as they are now with the new water pump, fresh coolant, and new fan clutch. It seems pretty weird considering it should be staying cooler than it was before with a leaky water pump and dirty coolant.
  2. Jan 5, 2019 at 5:30 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Did you burp the system to remove air pockets?
  3. Jan 5, 2019 at 10:21 AM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
    Anybody know at what temp the thermostat is fully open? I think attempts to keep it cooler than the full open temp will just result in the thermostat throttling down to bring the temp back up. If it's getting hotter than full open temp then it's time to do something about it. Haven't messed with the Tacoma much but got an ultragauge and done a bunch of research on the 80. I watch that one like a hawk.
  4. Jan 5, 2019 at 11:30 AM
    betterbuckleup
    Ian
    Concord, CA
    As far as I know all I had to do to burp the system was run it with the radiator cap off and fill it as air pockets come out and the level went down.
    I did this, but if there is something else I missed let me know.
  5. Jan 5, 2019 at 2:00 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Shamal likes this.
  6. Jan 5, 2019 at 2:05 PM
    betterbuckleup
    Ian
    Concord, CA
    Earlier today I actually went out and bought that exact thing. Although it seems the system is already full and clear of air because it won't drink any more coolant.
    I have been looking into the thermostat now. I have never touched it since owning the truck so maybe its on its way out?
    I'm debating about pulling the trigger on the LCE 180 degree thermostat. I just really don't want to have to drain the coolant all over again to swap the thermostat. But if it comes to that, so be it.
    https://www.lceperformance.com/ProductDetails.asp?ProductCode=1032078&CartID=1
  7. Jan 5, 2019 at 2:07 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    I’d try burping it with the funnel first if that doesn’t work move to the thermostat.
  8. Jan 5, 2019 at 2:09 PM
    betterbuckleup
    Ian
    Concord, CA
    That's pretty much the point I am at.
    I am going to try again later when it has had a chance to completely cool down, then run it with the funnel on for about 10 minutes.
    If I don't see any more air come out, i'll probably order a thermostat. $30 isn't too bad for a better thermostat and gasket shipped to my door.
    DW85[QUOTED] likes this.
