Idle?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PooTaco, Nov 25, 2023.
  1. Nov 25, 2023 at 8:16 PM
    PooTaco
    PooTaco [OP] Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    Is it pretty normal for a gen 3 to idle high when started?
    1200-1300 rpm, I hate waiting for it to come down before putting the truck into gear.
  2. Nov 25, 2023 at 8:23 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Any vehicle vehicle I’ve owned over the past 30+ years has had high idle on cold start.
  3. Nov 25, 2023 at 8:25 PM
    PooTaco
    Utah
    I agree, mine all do also.
    The tacoma just takes quite some time to drop down a bit, I hate throwing it in gear with the idle high.
    Stevie17 likes this.
  4. Nov 25, 2023 at 8:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Nov 25, 2023 at 10:19 PM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
  6. Nov 26, 2023 at 6:19 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    How long are u waiting ? Mine does it on the initial start up then drops down to 500rpm within a minute or less .gives me enough time to connect my iPhone and pick my radio station .
  7. Nov 26, 2023 at 7:31 PM
    PooTaco
    Utah
    Runs high for about 5 mins on every start.
  8. Nov 27, 2023 at 3:24 AM
    Mallcrawler20
    It shouldn’t run that high for that long .start with basics check air filter and clean your mass air flow sensor it’s super easy to do .
    PooTaco[QUOTED][OP] likes this.
  9. Nov 27, 2023 at 3:32 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I give it a few seconds for oil to circulate, then drop it in gear. No clunks, etc.
    Stevie17, PooTaco[OP] and Chew like this.
  10. Nov 27, 2023 at 3:38 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Depends where you live and what the temp is when you start. You don't need to wait for it to come down to put it into gear. Just a few seconds to make sure the oil is flowing. Ideally you'll let some heat build up but I get not every situation warrants that.
    Keep in mind that most of the engine wear occurs before the engine comes up to operating temp so take that for what it is worth.
  11. Nov 27, 2023 at 5:51 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    My 2018 and 2023 idle this long when its cold out.
    Stevie17 and PooTaco[OP] like this.
  12. Nov 27, 2023 at 9:02 AM
    PooTaco
    Utah
    Its around 35 degrees f.
    Air filter was the first thing I changed.
  13. Nov 27, 2023 at 3:42 PM
    RedWings44
    Michigan
    For what it is worth, I'm sitting in my truck at 22°F with idle around 1300 RPM after starting it a few minutes ago. It's just trying to build up heat a bit faster in the engine.
  14. Nov 29, 2023 at 7:33 PM
    Jruk
    Jruk Un-Known Member
    Middle West of the US of A
    2021 Army Green TRD Off-Road DCSB 4x4
    It’s normal, especially in cold weather
    PooTaco[OP] likes this.
