Idler pulleys and belts
Discussion in '1st Gen. Tacomas (1995-2004)' started by dammit boy, Dec 20, 2024.
  1. Dec 20, 2024 at 7:11 PM
    dammit boy
    dammit boy [OP] Member
    1998 reg cab 2.4L
    none
    I have a 1998 regular cab SR5 four-cylinder 2.4 L. Making a noise like a whining noise or low squeal. I figure it is probably one of the idler pulleys. Truck has 176,800 miles on it.
    Does anyone know what the Toyota OEM part numbers are for the two idler pulleys and the belt.
  2. Dec 20, 2024 at 7:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This site is amazing for getting you full blown diagrams of every different part of your truck as it'll include part numbers (both original, and revised) - https://partsouq.com/
    SecureIT2021 likes this.
  3. Dec 22, 2024 at 11:42 AM
    dammit boy
    1998 reg cab 2.4L
    none
    Thank you so much. This is exactly what I need. I was actually looking for schematics, but could not find but a very few. Thanks again,
    Kwikvette likes this.
  4. Dec 23, 2024 at 6:17 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I bought aftermarket Gates pulleys. P/N 38031. Made in Canada. Worked well. Another option is to just replace the bearings in the pulleys. I did this on the ones that I removed so that they are ready for the next replacement. The sealed bearing you want is a NSK 6301 with double rubber seal.
    BTW, the noise I was chasing was not resolved by the new pulleys. Oh well.
    Black97v6MT likes this.
  5. Dec 23, 2024 at 11:48 AM
    dammit boy
    1998 reg cab 2.4L
    none
    Thanks for the info. I’ll check into those bearings.
  6. Dec 24, 2024 at 5:16 PM
    dammit boy
    1998 reg cab 2.4L
    none
    I checked into the gates pulley 38031 and the pulley itself is made in Canada, but the bearings are made in China so it’s basically a piece of crap
  7. Dec 25, 2024 at 11:45 AM
    NC Gazzer
    Durham, NC
    The bearing in the Gates pulley that I installed was marked NTN so probably not a piece of crap. NTN has a bearing factory in Canada so I presume that's where it came from. In any case, we'll see if this Gates pulley is up to the task. The new bearing spun nice and smooth, but then again so did the bearing in the original.
    I hope you solve your squeal. I'm still hunting mine down
  8. Dec 25, 2024 at 6:33 PM
    dammit boy
    1998 reg cab 2.4L
    none
    Sorry, I just got one from Amazon and I am returning it because the bearing is made in China.
