Idler Pulleys / Tensioner Pulley / Serpentine Belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CIAGDDS, Jun 2, 2013.
  1. Jun 2, 2013 at 7:13 PM
    CIAGDDS
    CIAGDDS [OP] Well-Known Member
    Corona, Ca.
    05 4x4 TRD OR
    I attacked this project today, my truck has 124,000 miles on it and when I checked my pulleys they all wobbled and I was getting some weird noises under the hood. The three idler pulleys are easy. The Tensioner pulley sucks the big one. It took me 4 hours to get the tensioner out and in. Very tight space to work in. It was worth it in the end. The engine runs a lot quieter.
    I used post #3 in this tutorial to help me:
    http://www.fjcruiserforums.com/foru...154-idler-pulley-bearing-failure-what-do.html
    You definitely need to remove the fan and shroud to get the tensioner out, no need to remove the battery. Just disconnect the negative terminal before yanking the alternator. If you're just replacing the idler pulleys you can go in from underneath, remove the front skid guard, loosen the serp belt and just unbolt the pulleys, probably take 15-20 minutes for just those.
    This is what I replaced:
    Parts (Ordered all Gates products from RockAuto):
    (x2) Upper Pulleys (#2): 36173
    (x1) Lower Pulley (#1): 36174
    (x1) Tensioner w/Pulley: 38411
    Serpentine Belt: K070834
    Got everything for $194 shipped with a coupon code from retailmenot.
    Key-Rei, gc4078, pats73 and 4 others like this.
  2. Jun 3, 2013 at 11:58 AM
    Soft Taco
    Soft Taco For Love of Truck
    Tyler
    Schofield Barracks, HI
    White 2006 TRD
    6” Fabtech
    Great info! Saved for distant future use.
  3. Jun 3, 2013 at 12:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just did this the other weekend to my truck, replaced the 3 idlers and the pulley on the tensioner. I also used Gates pulleys and a Gates belt from Rock Auto. I purchased the entire tensioner assembly but only ended up replacing the pulley. Replacing the whole arm looks to be a PITA. I pulled the new pulley off the new assembly and just swapped the pulleys. It's not overly hard and saves a LOT of time (no need to remove anything). Just remember, the pulley on the tensioner is reverse threaded!
    freddy2923, basically_stock_ and Crom like this.
  4. Jun 3, 2013 at 1:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The 36174 pulley will replace the idler pulley. One uses a spacer and one does not (I can't remember which is which).
    No need to buy the whole arm unless it has malfunctioned beyond just the pulley...
  5. Jul 8, 2013 at 6:39 AM
    rizzo20
    rizzo20 Active Member
    Central PA
    TRD Off Road
    just for clarification 36174 will replace the Tensioner pulley? I'm confused :D
    Manfred likes this.
  6. Jan 8, 2014 at 7:17 PM
    udelslayer
    udelslayer Well-Known Member
    North Carolina
    09 Taco 2wd 5AT
    Resurrecting this thread:
    Has anyone replaced the entire tensioner? The three bolts on the front look straight forward, but is the hidden bolt behind it a pita? I cant find the procedure for this. Is it that straight forward? The linked thread is for the V6. I'm working on the I4, 2.7.
  7. Mar 31, 2014 at 12:49 AM
    BeeRadd
    BeeRadd ANTI-DARK
    Brad
    Fountain Valley, CA
    2008 DCLB 4x4 TRD Sport
    Mag light mod, ABS Kill switch, On board air, tail-gate theft mod, Redline hood struts, Shovel mount, Rubberized undercoated frame, CB radio w/lil wil magnet antenna, LED interior light, Shocker 228 Train horns, black valence, fog lights anytime, black hood scoop, eyelids, anti-seatbelt chime hack, weathertechs,
    This thread helped me! The link to the FJ cruiser forum write up is perfect. Not as hard to do this as I thought
  8. Apr 14, 2014 at 2:01 PM
    Manwithoutaplan
    ID
    Great find. I did my pulleys and alternator but got scared about the tensioner looks pretty straight forward what are the bolts holding the ac unit and tensioner?
  9. Apr 14, 2014 at 2:05 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I have a picture of all the torque values and part numbers in my TW album.
    1) Loosen pressure on belt with 3/8" ratchet and insert screwdriver/awl into center of tension arm to release pressure.
    2) Remove belt
    3) change pulleys
    4) have fun reinstalling belt correctly (hardest part for me) :D
    5) wave at the people changing the tension arms when it's not needed
    Rudyp.27 likes this.
  10. Apr 14, 2014 at 2:13 PM
    Manwithoutaplan
    ID
    Y would you wave at them? :rolleyes:
  11. Apr 14, 2014 at 2:16 PM
    Pugga
    Massachusetts
    I drew a diagram before I removed the belt so I wouldn't f-up the install. It's absolutely ridiculous that Toyota didn't put the belt diagram under the hood :mad:
    Volunteer and Crom like this.
  12. Apr 14, 2014 at 2:19 PM
    Manwithoutaplan
    ID
    Very true i just went back to internet and printed out pulley design. I had the belt going the wrong way before i double check with the sheet.
  13. Apr 14, 2014 at 2:22 PM
    Manwithoutaplan
    ID
    Anybody done there crank Pulley( harmonic Balancer) ??
  14. Apr 14, 2014 at 2:22 PM
    XXXX
    sKiP
    05 Prius
    Because its a shit load of work taking 3-4hrs when all that's typically needed is a 5 min pulley swap. Also cost 10x more.
  15. Apr 14, 2014 at 2:24 PM
    Manwithoutaplan
    ID
    Do you know the pulley number??
  16. Apr 14, 2014 at 2:27 PM
    XXXX
    sKiP
    05 Prius
    Yea. On my way home now. Post it in a little.
  17. Apr 14, 2014 at 2:28 PM
    Manwithoutaplan
    ID
    :popcorn:
    Get on it philly boy
    Lets go Rangers !!!! :p
  18. Apr 14, 2014 at 2:37 PM
    XXXX
    sKiP
    05 Prius
    Oh you want the wrong part number. Np
  19. Apr 14, 2014 at 2:38 PM
    Manwithoutaplan
    ID
  20. Apr 14, 2014 at 4:00 PM
    XXXX
    sKiP
    05 Prius
    Tension pulley is a No.1 36174.
    Go Sharks!!!
