Idling problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, Sep 1, 2024.
  1. Sep 1, 2024 at 10:36 PM
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    I have a 2008 tacoma 2.7 with a 5 speed .. two days this problem showed up suddenly, after I disconnected the battery and connected it i started the car the rpm is idling around 400-500 and sometimes I need to push the throttle pedal while starting the car otherwise it will start and immediately will die, even when I am driving the car once i press the clutch the rpm will drop to 500 and it happened one time that the car turned off after the rpm drops.
    While driving the car i have no issues even the throttle response is perfect the only issue is the idle I tried and cleaned the MAF sensor and the throttle sensor and disconnect the battery but nothing changed i know many of u have faced this issue so please if anyone can help i really appreciate that
  2. Sep 1, 2024 at 11:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you clean the throttle body?
  3. Sep 1, 2024 at 11:21 PM
    Neticstacoma
    Thank u for the reply This time actually no but few months earlier I did clean and if was not that much dirt, do u think a dirty throttle will cause idle issue in that way? Or is it related to sensors
  4. Sep 1, 2024 at 11:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pop the #4 coil out (because it’s easiest to get to). The tip should be dry. If it’s wet with oil, you need new spark plug tube gaskets. Good luck!
  5. Sep 2, 2024 at 1:17 AM
    Neticstacoma
    speaking of that last time i changed the plugs I noticed some oil on them
    Steves104x4[QUOTED] likes this.
  6. Sep 2, 2024 at 4:00 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    There you go.
    tacoma16 likes this.
  7. Sep 2, 2024 at 4:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    On the electrode or where the wires mount?
  8. Sep 2, 2024 at 7:33 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    90% of the time a low idle especially after a battery disconnect is a dirty throttle body, throttle body cleaning is almost always the first thing I do for a low idle/stalling complaint.
  9. Sep 2, 2024 at 8:13 AM
    Neticstacoma
    UPDATE the problem is solved
    Thanks that exactly what it was! I cleaned the throttle body + intake manifold ( without removing only what my hands could access) and now its working perfectly the idling is perfect
    Jimmyh and Dm93[QUOTED] like this.
