If an EMP hit what parts would we need on hand to get up and running?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Feb 6, 2022.
  1. Feb 6, 2022 at 2:07 PM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Curious to know what parts we would have to replace to get the Taco back up and running after an EMP strike.
    What say you TW?
    seniorredwood likes this.
  2. Feb 6, 2022 at 2:22 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Dude...it's Sunday. You're 2 days late.
  3. Feb 6, 2022 at 2:32 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Battery, ECU, BCM, trans brain if auto would get you moving again but you'ed have all kinds of lights and be in limp mode as effectively all sensors would be knocked out, essentially you would need to replace anything that carries or holds current.
    In your theoretically improbable situation were your truck to be hit by an EMP you would effectively need a new truck.
    That said if you were in an area high enough profile and tactically desirable enough to be worth being EMP'ed you would probably already be dead or would be dead soon.
    I wouldn't worry about it as it's an extreme statistical improbability and effectively fuck all you can do about it if it ever were to happen, which it won't.
  4. Feb 6, 2022 at 2:33 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    It would be easier to keep a points-based ignition VW beetle around than deal with this.
  5. Feb 6, 2022 at 2:36 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Wrap your taco in Reynolds Wrap. You'll be good homes.
    Robo1958, Sudsman44, Hobbs and 8 others like this.
  6. Feb 6, 2022 at 2:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pocket knife and a bicycle
  7. Feb 6, 2022 at 2:49 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  8. Feb 6, 2022 at 2:49 PM
    OpeCity
    Long Beach, CA
    Also, it’s worth noting that an EMP is a much shorter-range problem than many people assume. You’re probably going to worry more about the nuclear pressure wave than the EMP
    Gunshot-6A, 4x4Taco2012 and Key-Rei like this.
  9. Feb 6, 2022 at 3:09 PM
    Kracken65
    Kracken65 Well-Known Member
    2005 TRD OFF ROAD 4x4 access cab 4.0 silver 6 speed manual
    3
    Rig it up where you can have a team of horses pull it.
  10. Feb 6, 2022 at 3:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Good footwear and stamina.
  11. Feb 6, 2022 at 3:33 PM
    Key-Rei
    Key
    Florida
  12. Feb 6, 2022 at 3:45 PM
    soggyBottom
    soggyBottom Well-Known Member
    Pretty sure it's going to be just about anything with an electrical wire coming out of it in your Tacoma. Unless you're willing to swap every single transistor over to tubes, or swap you truck for a very old vehicle, don't bother.
    On the other hand, the range of EMP from nuclear weapons is only a couple hundred miles in the absolute worst case. In reality it's likely less than 100 miles.
  13. Feb 6, 2022 at 4:02 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    From what I understand.....even parts on hand would be fried.
    I'll keep my bicycle handy........although, I don't think it will be needed.
  14. Feb 6, 2022 at 4:07 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Unless you have an emp proof bunker to put all your spare parts in.. you're done either way
  15. Feb 6, 2022 at 4:12 PM
    Toyko Joe
    Toyko Joe Here for the pictures
  16. Feb 6, 2022 at 4:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    If I'm close enough to see a nuclear flash, I'm going towards it. Not interested in surviving a mess like that.
    Or if I chicken out, I'll just hide under my desk like they taught us in elementary school in the '60s when Cuba was saber rattling.
    Duck and cover.........
    Kahpo, Turdyota3000, BuddyS and 10 others like this.
  17. Feb 6, 2022 at 4:17 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Some vehicle made in the 60s or early 70s.
  18. Feb 6, 2022 at 4:21 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    A faraday caged building to house your truck and goodies
    Or a carburator swap kit lol
    Voltron4x4, jsi, 18CHUÑO and 2 others like this.
  19. Feb 6, 2022 at 4:21 PM
    davidstacoma
    David
    NC
  20. Feb 6, 2022 at 4:54 PM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Front Runner load bars, Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost
    Might want to look at an old military CUCV (Civilian Utility Cargo Vehicle) - the Army term for the Chevy P/U (M1008) and Blazers (M1009) of the early to mid 80's. Not much in the way of electronics. I drove them when I was in the Army and would still buy one today if I get the opportunity. You could get one already painted in camo.
    Key-Rei and Jacked Burton[OP] like this.
