if i got 285's, will my uca's still rub with 1" lift in front?
Discussion in 'Wheels & Tires' started by DreDog, May 29, 2012.
  1. May 29, 2012 at 10:17 PM
    DreDog
    DreDog [OP] Well-Known Member
    Andrew
    currently, i have adjustable 5100s set at 0 in front with stock uca's and 265s
    i want to run 285s. everyone says they will rub the uca's.
    if i set the 5100s to 1" will the 285s be okay and not rub the uca??
    my wheel back space is 4.5
    does anyone know?
    ive looked everywhere without answer
    i dont do serious wheeling and want to sell my camburg spindles and rear set up for 285's
    what would i have to set the 5100's to so that the uca's wont rum when i put 285's on?
  2. May 30, 2012 at 6:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They won't rub the ucas at all with 4.5 bs. With only 1" of lift though, they will rub terribly on the fender well and the cab mounts. Also the 5100s do not have a 1" setting.
  3. May 30, 2012 at 6:17 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Lift height will not effect the uca rubbing the tire. That would be caused by wheel width and backspacing. As said by KPT 4.5 is your goal. 1" Lift will have some heavy rub on the plastics and fenders though.
  4. May 30, 2012 at 6:20 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    This, also look into getting some OME 885x coils for the 5100s and have them at the "0" setting. You should be at 2.5 of lift on the front. It will rub, but with some trimming, it should be minimal.
  5. May 30, 2012 at 6:24 PM
    DreDog
    Andrew
    Okay thanks guys
  6. May 30, 2012 at 6:24 PM
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    Your adjustments on the 5100's are 0 .85 1.75 and 2.5. And yes you will rub the well like crazy but should not rub your ucas with 285's and 4.5 backspace. Sry to hear your selling your Spindles, i would have bought them if i still lived in Whittier. but ill never sell my spindles.
  7. May 30, 2012 at 6:25 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I've got 285's with 4.5BS wheels and 5100's set at 2.5 and I had to do some minor trimming on the plastic and a tiny bit on the bumper. Alignment is fine except for caster and no rubbing on the UCA.
  8. May 30, 2012 at 6:40 PM
    DreDog
    Andrew
    Actually my back spacing in 4.76 with a -6 offset. It should still work without rubbing the uca right?
  9. May 30, 2012 at 6:42 PM
    KPT
    09 Prerunner
    Barely, but yes
  10. May 30, 2012 at 6:42 PM
    DreDog
    Andrew
    .85, I always just round to 1 for some reason
  11. May 30, 2012 at 11:33 PM
    DevL
    DevL Well-Known Member
    Its more than just "some trimming" it is extensive. Front and rear fender trimming, removing most of the fender liner, chopping the frame/cab mounts, cutting back the steel on the fender, hammering the pinchweld, installing rear axle relocation plates... all that is needed to run 285s or you will eventually rip off and samage your fender flares or cut yor tires etc.
  12. May 30, 2012 at 11:36 PM
    DevL
    And once you correct the alignment with a new uca your tires will rub every speed bump you go over... and smash int fender metal everytime you enter or exit a steep driveway at speed.
  13. May 30, 2012 at 11:43 PM
    krimson
    krimson Nothin
    TRD Off Road
    What rear trimming? I've never heard such A thing :confused: I've trimmed the front fenders on my truck and I barley rub now only at full lock. I do need to do the cab mount chop, but I only rub there when I go wheeling at full flex on the front. I'm sorry, I didn't say EXTREME CUTTING WILL BE REQUIRED TO RUN 285s :notsure:
  14. May 31, 2012 at 7:12 AM
    Large
    Large Red
    I know 2 members who use 2.5 on billies, run 285s, and have zero rubbing lock to lock. There are a few variables like BS, the type of tire, and of course the aspect ratio of it. I'm running 285/70 on 16s and by the looks & mild flexing I do I could drop down an inch and still clear everything. Now my size is roughly a 32" tire & if I went to 285/75 it would be closer to a 33" tire and I'm sure there would be some mild rubbing, but to give an accurate answer to the op's question I am going to assume you mean 285/75/16, 285/70/17, or 285/65/18, no you won't rub the UCAs with that BS but you will probably rub everything else.
  15. May 31, 2012 at 8:08 AM
    DevL
    My description is what you need to fit a tire 33" or larger that is 11.5" or wider. Without an axle relocation plate your tire will rub the front of the wheel well and the inner top edge of the fender flare requiring trimming. After the plate, you may not need to trim the fender flare or you may need to trim a tiny bit from the rear of the rear fender flare (say if you run a 285/75r17) or get a custom axle relocation plate that spaces off .5" instead of .75" that is the minimum on the generic axle relocation plates.
    All this assumes you are not willing to sacrifice up travel with longer bump stops.
  16. Jun 15, 2012 at 5:47 PM
    Taco-NB
    New Brunswick
    Sounds like a good reason to not waste money on new UCA's!
