If I knockout with propane heater running in my shell will I get poisoned and die?
Discussion in 'Product Reviews' started by YotaGangYotaGang, Oct 15, 2021.
  1. Oct 15, 2021 at 12:05 AM
    YotaGangYotaGang
    YotaGangYotaGang [OP] PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    So I have this my lil buddy heater which is powered by those lil coleman propane tanks and I sleep in my truck shell, if I knockout with it on will I get poisoned and die? Serious question, just is crazy to me if the fucker leaks ill be dead, i do have a co2 detector but still, how safe are these thibgs really.
  2. Oct 15, 2021 at 12:55 AM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    If you want to be sure you wake up alive use that CO detector
    Is it new? Go buy a new one if its not, they come now with as a sealed unit with a 10 year battery.
    Don't fuck around with CO!! It's called the silent killer for a reason!
    Also keep anything flammable away from your heater like bedding, clothes etc!
    Be safe, stay alive
  3. Oct 15, 2021 at 1:01 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    If you have ventilation then it shouldn’t be a problem huge problem…but like all the vents open…
    The issue is not as much as carbon dioxide as it is carbon monoxide. Which propane heaters do in fact produce. On a much smaller issue, fire in general will eat up oxygen is small space with no airflow.
    I realize opening up the window vents is counter productive to heating the space…for that reason I’d say a electronic heater or some good down would be your best option.
  4. Oct 15, 2021 at 1:20 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Use a CO detector. They're very loud and should go off well before levels are high enough for any health issues start. Yes these things can be dangerous but following the instructions will definitely help avoid any of those issues. If they were that big of an issue though they likely wouldn't sell them or they'd specifically say they weren't for indoor use.
  5. Oct 15, 2021 at 1:41 AM
    dfanonymous
    It literally says in the directions…”leave a window open of 12 square inches.” It also says there’s a sensor that will shut it off if it detects carbon monoxide…so there’s already a detector built into it.
    Because the manufacture knows sensors fail and IF you wake up to figure out your mistake…you’ll have a nice headache.
  6. Oct 15, 2021 at 1:56 PM
    YotaGangYotaGang
    Covina
    Lol thts why im asking and seems crazy to me some people play with death like this, which is why im asking, i have a toper with 3 vent windows
    Fatback17[QUOTED] likes this.
  7. Oct 15, 2021 at 1:58 PM
    YotaGangYotaGang
    Covina
    i didnt know the lil busdy heater had a built in shutoff, yeah I got 3 vents in my topper
  8. Oct 15, 2021 at 2:53 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    A camper shell is too small an area to use any propane heater safely in. Many many people have died from carbon monoxide poisoning in confined areas and some die every year. If you open the windows and vents wide enough to dissipate the carbon monoxide safely the heater will not be effective. I wouldn’t trust a c0 detector in a small place like a shell. Those devices can fail as can the batteries.
    You mention those devices leaking but it’s not leaking that will kill you. When the fuel burns to make heat, carbon monoxide is created and that’s what kills people. Carbon monoxide is odorless so you won’t smell it.
    I read not long ago about a young couple who went camping in a full size pickup with a large overhead camper. A very cold night so they turned the propane heater on. They were both dead the next morning.
    Just dress warm and get a damn warm sleeping bag. Forget the propane heater.
    BuddyS, vicali, 06Tacooo and 3 others like this.
  9. Oct 15, 2021 at 2:56 PM
    dfanonymous
    I made a mistake since that was off memory. That was an older model. they made it “4 square inches” of ventilations.
    Also the sensor is a oxygen sensor, so it accounts for carbon dioxide but monoxide is still a problem and written all over the instruction manual
    https://www.mrheater.com/mwdownloads/download/link/id/33/
    Pearson likes this.
  10. Oct 15, 2021 at 2:56 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Yes. You will die.
    Pearson and barf like this.
  11. Oct 15, 2021 at 3:12 PM
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    Yeah don't screw around!
    That little heater is probably way overkill for what you're using it for but whatever you use if it burns any kind of fuel protect yourself from CO!
    Good deal here, on sale for $32 & it'll save your life!
    https://www.amazon.com/Kidde-P3010C...ed+battery+co+detector&qid=1634335175&sr=8-12
  12. Oct 15, 2021 at 3:16 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The heaters have sensors built into them that will shut them off if levels get high or they get tipped over. But more precaution is never a bad thing.
  13. Oct 15, 2021 at 3:20 PM
    YotaGangYotaGang
    Covina
    i wont use it then, ill buy one of those cig lighter adapters that can connect to a lil home electric heater, oh and if my battery dies i have 2 jumper batteries. Now I have this lil buddy hearer never used
    06Tacooo likes this.
  14. Oct 15, 2021 at 3:27 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    That "SENSOR" is just a pilot light and a thermocouple. If the pilot light does not have enough oxygen to burn, then the thermocouple gets too cold and shuts off the gas. Completely mechanical process.
    Don't let if fool you that it's actually actively sensing anything
    Bivouac, 06Tacooo and GrizzledBastard like this.
  15. Oct 15, 2021 at 3:38 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Just get a warm down sleeping bag.
  16. Oct 15, 2021 at 3:46 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    NOOOOOO! A CO detector will not wake you in time. Get a proper heater that ducts the exhaust out and uses forced clean air for heat. Amazon sells diesel powered (heating fuel) 12v (for the fuel pump and air blower fan) that don’t make you breathe the exhaust fumes or rely on a CO detector to protect you.
    I run mine outside and have a dryer vent hose blow the heated clean air into our RTT.
    12V 5KW Diesel Air Parking Heater Air Heating LCD Switch Thermostat for Truck Boat Caravans Campervans w/Silencer https://www.amazon.com/dp/B07W66KXR8?_encoding=UTF8
    tacoma_ca and wilcam47 like this.
  17. Oct 15, 2021 at 3:50 PM
    OnHartung'sRoad
    ^^^that and a girlfriend or golden retriever!
  18. Oct 15, 2021 at 4:39 PM
    Sprig
    Ken
    Go with a golden retriever, they are faithful and more dependable than a girlfriend.
    Gearheadesw, otis24, Hobbs and 11 others like this.
  19. Oct 15, 2021 at 7:44 PM
    YotaGangYotaGang
    Covina
    So I bought a inverter that plugs into 12v socket that will let me run my lil electric heater, thanks yall
    Maximum Average likes this.
  20. Oct 15, 2021 at 7:55 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Bad choice.
    You'll be better off with a sub-zero sleeping bag with no heat in the shell.
    Before you go to sleep, strip off all your clothes and put on fresh, clean, DRY clothes. Wool socks and a stocking cap. Don't drink alcohol.
    You'll be fine.
    I have slept in a canvas pup tent in below zero temperatures without heat following those guidelines.
