If I knockout with propane heater running in my shell will I get poisoned and die?
Discussion in 'Product Reviews' started by YotaGangYotaGang, Oct 15, 2021.
  1. Oct 15, 2021 at 10:27 PM
    YotaGangYotaGang
    YotaGangYotaGang [OP] PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    So I purchased an inverter was 400 watt and the lil heater i bought was 400watt and itll start but then the inverter will poop out, I have the inverter connected to DC 120v outlet (cig lighter). What gives? If I have this correctly the cig lighter can only output around 100w-200w cus its connected to the cig lighter as opposed to the actual battery where I can get the full 400w with battery connections to the terminals? Thx for the help. If this inverter experiment doesnt work then I think its better to just buy a generator imo.
  2. Oct 16, 2021 at 6:55 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    electric heat will kill a battery super fast. Unless you want to run a generator all night, dont bother.
    The diesel parking heaters are EXTREMELY common and well reviewed in the RV and camping world. they are knockoffs of the Webasto and eberspacher heaters.
    This one is mostly self contained. You can duct the heat into the bed of the truck.
    https://www.ebay.com/itm/313363146903
  3. Oct 16, 2021 at 6:07 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    OP: That one’s nicer than the one I posted, it has a box already built for it and is self standing. Just be sure the exhaust isn’t anywhere near the intake for the ducted heat fan. Best to leave it outside and then run a dryer vent hose into your tent from it.
    The only drawback to this type of heater is after a while the heat exchanger ignition chamber can get clogged up with soot so you have to open it up and clean it out, there are some videos on YouTube how to do it.
  4. Oct 16, 2021 at 6:15 PM
    Maximum Average
    Maximum Average Well-Known Member
    Curt
    Quicksand TRD off road
    Some little buddy heaters have low oxygen sensors and are supposed to shut off. I have one but I won't trust my life to it.
    I do intend on getting an electric blanket to plug into a jackery
  5. Oct 16, 2021 at 7:32 PM
    YotaGangYotaGang
    Covina
    how many watts does a blanket take out
  6. Oct 16, 2021 at 7:41 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    gases float & are found at different levels
    for example a fire detector near the ceiling ( near not jammed in proximity )
    is the best location usually 6-7 ft high
    ‘ carbon monoxide ‘ detectors are typically mounted incorrectly........
    best location is considerably l o w e r
    the head level while sleeping / prone approx 3 ft form floor
    camping the head would be lower than bed level
    U want it to wake U BEFORE U get sick
    BEFORE so U succumd to a gas U cant smell..................even in a ventilated area
  7. Oct 16, 2021 at 7:49 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    If I were frequently sleeping in my shell during the winter I'd look into properly installing a small inexpensive diesel heater.
    Propane heaters like the one OP mentions generate moisture so you wake up with everything being damp.
    texas angler likes this.
  8. Oct 16, 2021 at 7:52 PM
    YotaGangYotaGang
    Covina
    ima just get a electric blanket, i dont live out of my truck, just camp 6 times a year if that
    Gen3TacomaOBX[QUOTED] likes this.
  9. Oct 16, 2021 at 8:04 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I would assume laying at the same level as you would qualify and either way, is supposed to detect levels well below anything that would cause health issues.
  10. Oct 16, 2021 at 8:05 PM
    YotaGangYotaGang
    Covina
    PSA I’m not gonna use propane buddy heater and im not betting my life on some damn 50$ detector in my shell, aint worth it lol just gonna use an electric blanket
    Knute and verynearlypure like this.
  11. Oct 16, 2021 at 8:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I've been using a Buddy heater in my tent for three years (spring & fall camping). It burns really clean. I use a Kidde CO detector with a digital counter and it has never gone above zero. The heater's biggest caveat is it projects a lot of heat upwards, so it may soften/warp the shell in the spot above the heater.
    Vmax88 likes this.
  12. Oct 16, 2021 at 8:14 PM
    YotaGangYotaGang
    Covina
    ill be honest with you….. I wouldnt wana sleep next to one if i slept outside in the ground or a hamock, the fear just loses my sleep, aibt worth it for me. I read some stories of some other people who have died, shits sad.
  13. Oct 16, 2021 at 8:18 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    I’d find an auxiliary power unit that fits your budget and power consumption. Personally I’d shop around with Jackery.
  14. Oct 16, 2021 at 8:20 PM
    YotaGangYotaGang
    Covina
    100w blanket is good enough for me and the inverter.
  15. Oct 16, 2021 at 8:21 PM
    #35
    verynearlypure
    Ernest
    The Buckeye State
    Are you using the bed inverter? I must’ve misread where your power station kept shutting off.
  16. Oct 16, 2021 at 8:22 PM
    #36
    YotaGangYotaGang
    Covina
    oh i bought a lil heater and it was pulling 400w and my inverter was like around that peak wattage and it pooped out on me, so i’ll just use an electric blanket.
  17. Oct 16, 2021 at 8:24 PM
    #37
    verynearlypure
    Ernest
    The Buckeye State
    ELectric blankets are underrated. Glad you found a solution. Happy and safe exploring. :hattip:
  18. Nov 12, 2021 at 5:27 PM
    #38
    YotaGangYotaGang
    Covina
    Sorry for the revive thread but I had an idea if it were to get really effin cold, if I somehow put my lil buddy heater propane heater outside on a stool where its facing my windoor and I open the lil window to let heat in, will it melt my mesh for the window? has anyone tried this? I would imagine that it would be safe or counter productive cus the window is open, idk.
  19. Nov 12, 2021 at 5:56 PM
    #39
    4x4spiegel
    4x4spiegel Well-Known Member
    Sir , thanks for your service but did you not have any cold weather training in the corps?
  20. Nov 12, 2021 at 6:10 PM
    #40
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP....with all due respect. The path you are suggesting is a sure way to win the Darwin Award and be removed from the gene pool.
    STRONGLY urge you to go to a camping store and purchase a sleeping bag with a below 0*F rating.
    Or
    Get a small gas power generator, a 25-50 ft extension cord and an electric blanket. Set the genny away from the truck, use the extension cord, plug the blanket into the extension cord. Sleep on top of half of the blanket, pull the other half over you. You will be like a bug in a rug, nice-n-cozy.
    Last point, leave the propane heater for a large open, ventilated space. CO death is silent and permanent.
    davidstacoma, texas angler and Sprig like this.
