If I run 265/70/17s on my
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimk75, Jun 29, 2011.
  1. Jun 29, 2011 at 10:39 AM
    jimk75
    jimk75 [OP] Active Member
    Jimi
    Upstate NY
    05 Taco Sport DBL CB LB
    05 Tacoma, would this be okay? will they rub, how bad will the speedo be off? Anybody running these now?
  2. Jun 29, 2011 at 10:41 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I ran that size on my 09 on stock suspension
    No problem with rubbing
    Speedo will be bang on
  3. Jun 29, 2011 at 10:44 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    This is the largest size tire you can run under a stock height truck with zero interference. It's a great size to add a bit of meat in the wheelwells and they look great under a mild lift as well. I ran them under my '07 when it was stock and still run them under my 3" lifted '10.
    Hope this helps.
  4. Jun 29, 2011 at 10:45 AM
    squad314
    Marc
    Gotta get up a little earlier to beat OZ I guess. :)
  5. Jun 29, 2011 at 10:45 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    x2... Running the same size, and no rubbing or problem, speedo is dead on.
  6. Jun 29, 2011 at 10:46 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
    Depends on the wheels...I had a bit of rubbing on my 2010, disappeared with the lift (TSB + Billies @ 1.75").
  7. Jun 29, 2011 at 10:51 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    that's the same exact tire i'm running now and no rubbing for me. I"m still at stock height
  8. Jun 29, 2011 at 10:58 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Same as others, stock height, 265/70/17, no issues. The speedo according to my GPS was a little off with the 265/65/17s. The new 265/70/17s fix it to be just about dead on.
  9. Jun 29, 2011 at 12:38 PM
    jimk75
    Jimi
    Upstate NY
    I have new stock springs but the mechanic took the old longest leaf, cut it to size, and added it. It rides great and is a little higher. It seems like it is 1-2 inches taller.
  10. Jun 29, 2011 at 12:41 PM
    OZ-T
    Peter North
    British Columbia
    You paid to put another Toyota 3 leaf pack in your truck ?
  11. Jun 29, 2011 at 2:44 PM
    jimk75
    Jimi
    Upstate NY
    Basically, I broke a spring, purchased an almost new set from this website, and when I had them installed, the mechanic took my old leafs, cut the longest one to fit, and added it to leafs he was installing.
  12. Jun 29, 2011 at 3:01 PM
    OZ-T
    Peter North
    British Columbia
    Gotcha
  13. Jun 29, 2011 at 3:06 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    I'm running 265 70 17 toyo mt ..on stock suspension
