If I was to buy a trickle charger which one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spitdog, Sep 25, 2018.
  1. Sep 26, 2018 at 2:00 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I've heard that some trickle chargers, never turn completely off, even when batt. is fully charged & can cause damage to the batt. by overcharging. Others switch "completely off" when batt. is fully charged, & only come back on when batt. slightly loses a little of it's charge. Not sure about tender/maintainers, but older chargers had a gauge, that never went down to completely "0", it kept charging, a tiny amount until charger was disconnected. The newer chargers have an indicator light. When batt. is completely charged, the charger turns completely off & the green light comes on, till the batt. loses a slight amount of charge, then turns back on till batt. is fully charged again. Is this a concern with tenders ?
    YF_Ryan likes this.
  2. Sep 26, 2018 at 4:35 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    been using a battery tender on an 8 year old battery in my boat. not the fastest, but i dont use my boat that often without giving it enough time to go into float. get the correct battery tender for your truck and youll be good.
    PzTank likes this.
  3. Sep 26, 2018 at 4:36 PM
    DEMikey
    mikey
    delaware
    2013 red taco
    the battery tenders will float (on and off) to maintain a full charge.
  4. Sep 27, 2018 at 7:52 AM
    96carboard
    96carboard Well-Known Member
    Battery tender will never stop charging, and will slowly drain the life out of your battery. The only reason they don't kill them in a week is because they're low current.
    They are NOT good for your battery.
    Get a NOKO.
    YF_Ryan likes this.
  5. Sep 27, 2018 at 8:00 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    NOCO is the best! Theyre not cheap but theyre really great!
    YF_Ryan likes this.
  6. Sep 27, 2018 at 9:23 AM
    smiles2
    smiles2 Well-Known Member
    2017 Blue Tacoma TRD Offroad
    I currently have a battery that I have been using with no issue since 2012 on the battery tender. Can you explain if its an issue with a certain model? From my understanding it automatically changes the charging mode depending on the charge level of the battery.
  7. Sep 27, 2018 at 9:31 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I use a Deltran Battery Tender Jr on my Drag Race car !! :thumbsup:
  8. Sep 27, 2018 at 9:40 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    YF_Ryan likes this.
  9. Sep 27, 2018 at 9:47 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I just punched up trickle chargers maintain/float mode, & from what I read when on float it is still charging from 0.2 & 0.6 amps
  10. Sep 27, 2018 at 11:03 AM
    96carboard
    @smiles2 ... ^^^ That.
  11. Sep 27, 2018 at 11:09 AM
    spitdog
    spitdog [OP] Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Just from the reviews on different chargers/maintainers they all seem too be prone to either working as they should or not work after a short period of time.
    Roll the dice I guess.
  12. Sep 27, 2018 at 11:21 AM
    spitdog
    inesshell[QUOTED] likes this.
  13. Sep 27, 2018 at 12:35 PM
    scocar
    scocar hypotenoper
    No need to roll the dice. You could make an educated decision. The CTEK and NOCO sites have lots of good info to help you decide your specific needs, as do some independent reviews.
    I have a CTEK (56-353) MULTI US 7002 that I chose for my deep cycle Northstar marine battery (expensive) that I use in my trailer. I have no need for one for my truck. It's been great.
    No need to go with the cheapo, and potentially useless or damaging, 40-year old technology for old "trickle chargers" any more than you should keep changing your oil every 3000 miles "because that's how grand pappy always did it in his Buick."
    Norton likes this.
  14. Sep 27, 2018 at 12:36 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    This is what I'm using !!!:thumbsup:
    TRDSport10, TXpro4X4 and spitdog[OP] like this.
  15. Sep 27, 2018 at 12:39 PM
    #35
    96carboard
    One thing that can be confusing to some people, with respect to chargers, is that these modern fancy chargers don't just switch on and pour power into whatever they're hooked up to. They actually need to sense a voltage before they're willing to start charging. This can make them seem "dead" if you try something silly, like hooking the probes of a multi-meter up to the charging terminals without a battery -- the charger won't register on the multimeter because it won't turn on under those circumstances. Similarly, if you try to charge a battery that is *completely* discharged, it won't do it. I've on occasion had to deal with batteries that were run *completely* dead, and in those instances, you need to jump start the charger by feeding it a voltage from another battery briefly until there is enough charge in the dead battery to keep the charger happy.
  16. Sep 27, 2018 at 12:40 PM
    #36
    96carboard
    Murderer! (of batteries).
    Not joking. Those will destroy batteries by overcharging.
    US Marine[QUOTED] likes this.
  17. Sep 27, 2018 at 12:42 PM
    #37
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    I use a basic old 750mA Battery Tender Jr. for my lead acid wet cell batteries. And have a CTEK for the AGMs that I don't keep in cars.
  18. Sep 27, 2018 at 12:48 PM
    #38
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    re Deltran Battery Tender Plus, I used one of those on my BMW motorcycle and got 7 years out of the battery, and 50000 miles.
    i characterized it with a volt meter to verify, its a true 4-stage 'smart charger', and is temperature compensating too, as long as the battery is at the same ambient temperature as the tender. it starts out with a battery test, then does a bulk charge phase at its maximum current (1.5 amps or something?), followed by an absorption phase of elevated 14.4V, then reverts to a maintenance/trickle phase of 13.5V or so, and once a month does a shorter absorption phase to 'wake' the battery up.
    I've used Deltrans for years, never had one kill a battery. obviously, a 1-2A tender won't *charge* a car/truck sized battery very fast.
    for my truck, I have a 15 watt solar charger/tender I put on the roof of the truck and plug in when its going to be parked for over a week.
    eherlihy and smiles2 like this.
  19. Sep 27, 2018 at 12:56 PM
    #39
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    It's hooked up to my Drag race car 24/7 , never had a problem
    Only thing that is killing my batteries is a locked out distributor and 11.75:1 comp
  20. Sep 27, 2018 at 12:57 PM
    #40
    Speedytech7
    Damn, 11.75:1, guess it isn't boosted then haha
