If it was my head gasket.
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Feb 22, 2012.
  1. Feb 22, 2012 at 9:27 AM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    I have replaced my valve cover gaskets and still have oil running down the back of motor..i cleaned it up and sat under the truck for 30 min running. during that 30min i did not find the source of the leak. there is oil above and below the head gasket so i dont think it is the head gasket...keep in mind i do have 216xxx on it. if it were the head gasket leaking or seeping what symptoms do i look for? Oh And i have never ever had coolant in the oil nor does it seem like i have bad compression the truck runs amazing...just cant figure it out. maybe still the valve cover gasket. and yes i put sealant on the gasket corners.....one more thing between oil changes i am not losing enough oil to notice on dipstick. I just F*&king hate hate hate leaks. Any help much apprecited....
  2. Feb 22, 2012 at 9:29 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    sry i cant help, i have similar issues, subbed for responces, and bump for you
  3. Feb 22, 2012 at 9:29 AM
    sir1123
    Charleston
    i guess i really just want to know head gasket symptoms for our trucks.
  4. Feb 22, 2012 at 12:41 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    It'd be smoking white if you had a leaky head gasket from burning coolant... That's about all I know
  5. Feb 22, 2012 at 12:43 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Exhaust bubbles in your rez and also might find some white foam under your oil fill cap
  6. Feb 22, 2012 at 12:49 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  7. Feb 22, 2012 at 12:55 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You don't put sealant on rubber gaskets.
  8. Feb 22, 2012 at 4:38 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
  9. Feb 22, 2012 at 7:39 PM
    sir1123
    Charleston
    there was sealant there from the factory. and the half moon peices do.
  10. Feb 22, 2012 at 7:47 PM
    sir1123
    Charleston
    wow thanks man well i am guessing it is the cam seal plugs....ha it is the only thing that isnt new in that area. and for the half moons i put alot of sealant there so now i need to get the seals and take it all apart. thanks so much
  11. Mar 14, 2012 at 7:39 PM
    sir1123
    Charleston
    okay so i have been doing research and cant find anything on the rear cam seals leaking. do they leak often on our trucks? i have taken valve covers off three times and resealed the halfmoon too and still i have oil seeping out back of valve covers. what the F could it be what am i doung wrong? please help!! i am NOT going to dealer or a shop. cant afford and gthey will just throw parts at it. So as of now i am thinking of getting a vc gasket from toyota and redoing it all again. do i need to just get the cam seals too?
  12. Mar 14, 2012 at 7:45 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    I haven't read the whole thread but are letting the sealent dry for alittle while before starting up again? also replacing the gaskets after messing with them some many times would be a good idea.
  13. Mar 14, 2012 at 7:48 PM
    sir1123
    Charleston
    the gaskets are brand new felpro so i dont think that taking off 3 times in basically 3 consecutive days would matter but ya maybe i didnt wait long enopugh
  14. Mar 14, 2012 at 7:49 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    are you using any additional sealent? what kind?
  15. Mar 14, 2012 at 7:54 PM
    sir1123
    Charleston
    on the half moons i used is pematex create a gasket silicon. i only used it to reseal the half moons and in 90 deg. corners at the base of the cam seal hump.
  16. Mar 14, 2012 at 8:41 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
  17. Mar 14, 2012 at 8:43 PM
    sir1123
    Charleston
    ya well thanks for the help. i guess i just need to redo everything again. really pissing me off but not bad for the only issue at 216xxx miles. KNOCK ON WOOD!
  18. Mar 14, 2012 at 8:45 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Very annoying indeed. Good luck with finding the cause.
  19. Mar 14, 2012 at 8:47 PM
    sir1123
    Charleston
    thanks and if i nail it i will make sure i post.
