If it's been said once...LCA bushings / Cams
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PMK, Sep 2, 2013.
  1. Sep 2, 2013 at 5:50 AM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Had to do some front end work yesterday to remove the left and right shocks.
    My truck is a 2010 Prerunner and I have been wanting to do some preventative maintenance on the LCA bushings and cams to prevent them from corroding.
    With the shocks removed, I marked the cams with a Sharpie felt marker. Pulled the bolts for the LCA, both aft pivots were fine, no corrosion. The forward bolts were fine, however the cams had corrosion on them as did the bushing ID. Everything still came apart easily but with time this would be ugly as others have found.
    I suspect the cams are not the real problem, they are plated. The bushing ID though is bare steel and seems to pose the concern.
    Regardless, I coated all the surfaces with Mastinox D40 http://www.ppg.com/coatings/aerospace/sealants1/mastinox.pdf
    and reassembled.
    FWIW, all the chassis items I have had apart, rear u-bolts, swaybar mounts, shock mounts, slider mounts etc. have had Mastinox D40 corrosion compound applied. Plus I keep a respectable application of Corr Ban 22 on everything I can spray it on.
    http://www.zipchem.com/products/product_detail.aspx?id=NjY=
    The LCA corrosion prevention is pretty easy and worthwhile. My truck is low mileage. The corrosion will happen on a street truck if you drive it in the rain or worse in the snow. The design has no provision to keep water out.
    Best of luck with it.
    PK
  2. Feb 27, 2016 at 8:00 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Has this helped since you posted in 2013?
    I think I have the same issue.
  3. Feb 27, 2016 at 8:37 PM
    Pigpen
    Dan
    Northwest Montana
    mine are fucked
