if u have locker ... do u have lsd?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 350u, Nov 24, 2010.
  1. Nov 24, 2010 at 4:05 PM
    350u
    350u [OP] Member
    ab canada
    07 access cab 4x4 trd
    I have the e-locker in my offroad access cab,but it seems to work as a lsd when in unlocked mode......wut up?
  2. Nov 24, 2010 at 4:15 PM
    zonataco
    zonataco Well-Known Member
    I believe you are correct.
  3. Nov 24, 2010 at 4:16 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Open diff.
  4. Nov 24, 2010 at 4:17 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    on the 05-08s have open, LSD, or e-locker....09+ have the auto LSD on everything and just the e-locker in the TRD OR.
    an 05-08 w/ the e-locker and it off is open
  5. Nov 24, 2010 at 4:33 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    x2
  6. Nov 24, 2010 at 6:44 PM
    michaelg589
    michaelg589 Well-Known Member
    So how bout the front diff? When I engage the locker, all 4 wheels spin. Ill dig myself into the dirt with all four wheels.
  7. Nov 24, 2010 at 8:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Front diff is OPEN in ALL tacomas from the factory.
    Did you buy the truck used? Unless the person before you put something in there, its hard to say WHAT it is. You gotta give us more information.
  8. Nov 25, 2010 at 8:41 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Typically when one becomes stuck... one tire per axle has less traction than the other so you see one spinning in the front and one spinning in the rear. This is open differentials.
    A-TRAC or LOCKERS elimintate non traction tires from spinning so torque goes to tires with traction and you drive out.
    Limited Slip system REDUCE torque to non trction tires and divert some to traction tires to help you move on.
