If you got to do your 3" lift again what would you...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Got2ryde, Aug 7, 2012.
  1. Aug 7, 2012 at 5:33 AM
    Got2ryde
    Got2ryde [OP] Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    If you got to do it all over again, what would you do the same, different, and which products would you use again or not and why? I'm trying to figure out what are my best options when doing a 3" lift on my 2012 Access cab Off road with a tow package and 3 leafs which it sounds like Toyota is not going to correct as it designed to have more offroad contouring with the 3 pack. I don't want excessive badassedness(well I do but I'm being realistic and doing a 3" for Daily Driver reasons). I'm a little reluctant to do anything that will void my warranty but I want to be able to use my truck like a truck. I loaded my motorcycle(160lbs) and camping gear(maybe 400lbs) and took a 3000 mile trip to Nationals and was really suprised at how much bottoming I did on the highway. Glad I didn't try to put both bikes in as she would have been sittin on the rubber stops. So now I have a Leer 180 and would like to get one of these http://www.joehauler.com/doublehaulers/doublehaulers.shtml which I know means I have to beef things up, as putting all that weight way back there and full of camping gear under the topper is going to need some upgraded equipment. Curious too what you guys think I might expect to pay for these upgrades.
  2. Aug 7, 2012 at 7:50 AM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    If i could start all over, I would go with some type of Extended Travel Coilovers and shocks all around. Deavers or All Pro Leaf Packs. And some type of Uniball UCA. My rear suspension has been redone 3 times. The front 2 times, 3 by next year. lol Problem is when you first start you don't really know what you plan on doing. I kept changing my mind.
  3. Aug 7, 2012 at 7:52 AM
    Geo Taco
    Geo Taco Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    I have a full OME set with 885 coils, LR UCA & AAL in the rear with OME struts. If I were to change it (which I most likely will), I would have gone straight to ICON extended travel coil overs in the front, ICON rear struts & full Deaver leaf pack.
  4. Aug 7, 2012 at 7:56 AM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    I would have skipped the AAL and gone with a upgraded leafpack. For now I am satisfied with the rest.
  5. Aug 7, 2012 at 8:54 AM
    Got2ryde
    Ryder
    Maryland
    This is exactly why I'm asking the pros! I want to do it right the first time in a way that I will be pleased with for as long as possible! Thanks for the feed back!
  6. Aug 7, 2012 at 8:56 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    im with you, im saving up to do it right the first time. ive definitely decided with new ucas, ome lift, but do the dakar leaf pack in the rear instead of aal
  7. Aug 7, 2012 at 9:16 AM
    i2andom81
    i2andom81 Well-Known Member
    Denver
    08 black prerunner
    Fox coilovers and resi rears, 20% tint, wet okole trd seat covers, LCE engineering headers, custom magnaflow exhaust, afe cai, satoshi grill, URD supercharger, retrofitted headlights, weather tech mats, standard duty leafs, allpro front bumper and uca
    I actually enjoyed my toytec lift kit. However, if I were to redo my 3" lift, I would go with downsouthmotorsports for the coilovers and ucas. For the rear, I would do allpro rear suspension packages like the posters above.
  8. Aug 7, 2012 at 10:22 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Allpro or Deaver over OME Dakar? I have my front end shocks and coils already and now its time for the springs I need. I have considered trying to find a set of tsb and doing a icon 3 leaf but the stock toyata springs suck either way it seems. So I am torn between what brand leaf pack to save up for.......its my next purchase:confused:
    Can you tell me why those brands have come up twice now before dakars?
  9. Aug 7, 2012 at 10:34 AM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    If I had to do it all over I would have skipped the lift all together.
    I currently have the following.
    RCD 4 inch
    886 front springs (It gave me an 2 inches more lift in the front.)
    Aclan real leaf with 4 inches over stock with 400 lbs pre-load. (I had to add a 1 inch block to make up for the 2 inches added in the front.)
    Total Chaos UCA's
    I would have just done uniball UCAS, a better real leaf pack 400-500 lbs pre-load. And I would have just armor plated the hell out of the underside.
  10. Aug 7, 2012 at 10:38 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Buy once, cry once.
    most peoples problem is they want to get something cheap and it be good enough. (me included)
    get a quality coilover and upper control arm for up front.
    for the rear grab some well known leafs, possibly even the firestone air ride kit since you haul gear. THis will help a ton with the rear weight.
    also look into a Hellwig rear swaybar
  11. Aug 7, 2012 at 1:57 PM
    Got2ryde
    Ryder
    Maryland
    So why would you have skipped it? And to everyone else, these are cold hard opinions I was looking for! Keep'em coming!
  12. Aug 7, 2012 at 2:11 PM
    Specalt
    Phoenix
    2001 TRD 4x4
    For every thing I have used my truck for it was just not needed.
    I have yet to be even close to maxing out my suspension. I take it camping and to the lake and some trails.. But I think I over built it. I would say I am worried to use my truck to 100% for the fear I might break the truck. (I guess that is why you build them that way) But I think I would be fine with full armor. For the $$ I have in the suspension. I could have spent 1/4 that on under armor.
    I love what I have and I'm glad it did it don't get me wrong. I'm not going to change it. But if this truck were to leave me I would not do it again.
  13. Aug 7, 2012 at 3:15 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this^^
    my lift, didnt buy me much..i only use it for hunting..some relatively tough trails, but nothing a stocker couldnt do. i'd use the money for something else.
  14. Aug 7, 2012 at 5:13 PM
    JayDirt
    JayDirt I owe it all to little chocolate donuts
    I'm thinking Camburg FTW.
    Uniball UCA's
    Fox Coil Over's with remote or without (front)
    Deaver Leaf Pack
    Fox 2.0 (rear)
    I think that adds up to be around $2500 to $3500 give or take. Way better than the (Fabtec) lift I had on my FX4...
    And I'm walking distance from their shop :D
  15. Aug 7, 2012 at 8:06 PM
    Got2ryde
    Ryder
    Maryland
    Are those numbers installed or DIY?
  16. Aug 8, 2012 at 6:36 AM
    JayDirt
  17. Aug 8, 2012 at 9:38 AM
    Got2ryde
    Ryder
    Maryland
  18. Aug 8, 2012 at 9:49 AM
    bjhn83
    bjhn83 Well-Known Member
    Bradley
    Columbia, MO
    05 SR5 DCSB Grandpa Shell
    3" Toytec lift, 285/75/16 BFG AT KO's on Pro Comp 7089's, Yellow fog lights, Satoshi
    Hey OP might be useful to update your post and ask posters to descibe the type of use the truck sees. For example someone that says they wish they had gone with icons all around might do alot more offroading than someone who is perfectly satisfied with billies and an AAL. Try to match truck use with lift-type is just my $.02 :D
    That being said I love my ebiachs, 5100's and 2" AAL. Got LR UCA's for good measure and don't regret my decision. I don't do any hardcore offroading so it works well. Havn't had the bed loaded up yet so no comment but I'm sure new leaf packs will be necessary in the future
  19. Aug 8, 2012 at 12:07 PM
    sytfu510
    Alex
    Bay Area
    Not sure if you're asking me, but I just named those because they were the first 2 I thought of. No preference between the brands, there's many threads going over the pros and cons and you can decide based on your own needs.
  20. Aug 8, 2012 at 2:57 PM
    Got2ryde
    Ryder
    Maryland
    Valid point, thanks for the input. I guess for me and my needs I am looking for equipment that will last and is the happy medium. Not going to be out pounding the trails and I also want to maintain ride quality for getting to the trail. I'm starting to think air bags are something to consider for my needs. I'm still a newbie at all this so I'm trying to learn about all the different options. I don't mind spending the $, just want to make it count when I do. There's a lot to consider into the equation. Like I know I want to do some armor and bumpers so gotta factor in the weight there. Just gotta keep reading the good words here in TW! Thanks again guys!
