If you got to do your 3" lift again what would you...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Got2ryde, Aug 7, 2012.
  1. Aug 9, 2012 at 12:05 PM
    #41
    Got2ryde
    Got2ryde [OP] Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    How many of you guys did your own installs?
  2. Aug 9, 2012 at 12:24 PM
    #42
    bjhn83
    bjhn83 Well-Known Member
    Bradley
    Columbia, MO
    05 SR5 DCSB Grandpa Shell
    3" Toytec lift, 285/75/16 BFG AT KO's on Pro Comp 7089's, Yellow fog lights, Satoshi
    I did. On gravel.... so regretable lol
  3. Aug 9, 2012 at 12:36 PM
    #43
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I did, in my driveway, took all weekend.
  4. Aug 9, 2012 at 1:26 PM
    #44
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    I plan to, at dads shop, w/ the fronts pre assembled. Its already costing enough without the 400+ some place would charge me for the install.
  5. Aug 9, 2012 at 1:59 PM
    #45
    87FoRunner
    87FoRunner MallTaco
    Cameron
    Memphis, TN
    05 TRD 4x4
    ARB. M8000. OME 886. Mickey Thompson Classic Locks. 285 Pro Comp XMT. Pioneer x930bt. Memphis SQ comps. Memphis S class 10. Kragen HIDs.
    I think it took me about 4 hours to do my OME kit, front struts and rear leaf pack...
  6. Aug 9, 2012 at 2:01 PM
    #46
    JDMcQ
    My biggest hitch was the Total Chaos UCAs and freeing up the rusted-in leaf spring bolts...And by freeing up, I mean eventually cutting.
  7. Aug 9, 2012 at 2:13 PM
    #47
    Got2ryde
    Ryder
    Maryland
    I guess with my last question I should have also asked what ability level you would consider yourselves. I've always done my own brakes. Had to drop the drive shaft out of my Tundra. Had a friend help me redo a clutch in my old 94 Toyo pickup. And I also replaced my A/C compressor in my Tundra. Just as a indication of my abilitys(still not sure if I'm going to try to tackle it myself). I would like to save the dinero and I enjoy learning how to do these things.
  8. Aug 9, 2012 at 2:32 PM
    #48
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    There are not special tools or any thing you need. Just a few metric wrenches. I would say you could do it your self.. The only thing you might not have depending on your lift is a way to compress the front springs.
    If your not sure how to do that, get a lift that has the front spring all ready on the shocks. A mess up with the front springs while installing new ones could = death. Oh and get good Jack stands.
    But all and all it is an y easy install.
  9. Aug 9, 2012 at 4:57 PM
    #49
    JDMcQ
    It really is an easy install. I count 26 fasteners and 4 wrench sizes (at least on a first gen). As long as you have the springs installed on the coilover and you don't have any rust issues, it is easy as pie.
  10. Aug 9, 2012 at 5:33 PM
    #50
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Good point. I've been told recently by the local 4WD shop that the alignment cams on the Tacoma have a tendency to seize up. They suggested that each time I get an alignment, get the tech to move all adjustment then do the alignment. Anti seize or grease would definitely help.
  11. Aug 10, 2012 at 5:16 AM
    #51
    Got2ryde
    Ryder
    Maryland
    Been there done that! It sucks. When we did the clutch in my Little Yta it was about 40 degrees and shitty lighting. The space I've got now is a well lit slab with ample room! So I should be good to go. Now to just figure out which lift kit I'm going to use and FIND THE TIME!
  12. Aug 10, 2012 at 5:35 AM
    #52
    bjhn83
    Bradley
    Columbia, MO
    Yea man as long as you can turn a wrench you're fine. A can of WD-40 or something along those lines comes in handy and a cheater bar was a must for me. Access to air tools would have been real nice...
    Oh and plenty of BEER! :cheers:
  13. Aug 10, 2012 at 8:58 AM
    #53
    Got2ryde
    Ryder
    Maryland
    [QUOTE Oh and plenty of BEER! :cheers:[/QUOTE]
    Mmmm beer!
  14. Aug 10, 2012 at 12:05 PM
    #54
    Got2ryde
    Ryder
    Maryland
  15. Nov 8, 2012 at 10:43 PM
    #55
    kbraunphoto
    kbraunphoto mountain bike haulin' & off camping
    Kevin
    Atlanta, GA
    '15 Inferno Orange TRD Pro
    Just a few expensive & DIY things...
    Bump:
    I'd be interested in what each driver uses the truck for.
    Working on an expo build of sorts.
  16. Nov 9, 2012 at 8:20 AM
    #56
    ExtremeCustoms505
    ExtremeCustoms505 Well-Known Member
    Albuquerque WS
    2010 Tacoma 4d 4x4
    3" Revtek spacer kit in front w/ aal and 1" block in rear. No TSB aal installed yet. Spider Trax spacers.
    Like the others have said, you get what you pay for.
    Don't cut corners, do it right to be happy.
    I planned on the toytech ultimate kit, but to save a few bucks I went with the 3" Revtec spacer kit for the front and it came with 1 aal for the rear which left the rear sagging at all times. So I had to add a 1" block, new u bolts, and billy's to the rear just to make it ride level and semi decent. The front spacer makes it ride like a brick and will soon be changed again with a quality coil over and shock.
    And after all this not, including my labor I have only saved about $300 over the Toytec kit at my shop prices.
    Spacer kits are junk no matter what type of driving you do.
    Buy quality parts and continue to enjoy your truck.
    Also with the weight the OP is hauling air bags are a great addition, as others have also stated.
  17. Nov 11, 2012 at 9:54 AM
    #57
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    spacers and aal. no problems here.
  18. Apr 5, 2013 at 8:08 AM
    #58
    Matlax
    Matlax New Member
    Upstate NY here so lots of salt . Do you have any examples of ball joint style? Any downside to them? Also, anything to be careful with if I pull the Dakars apart before installing? Thanks!
  19. Apr 5, 2013 at 8:14 AM
    #59
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I'm upstate NY as well and concerned with salt. I'm constantly spraying it down to keep the salt from sitting.
    What have you done so far? Pics!!
  20. Apr 5, 2013 at 8:16 AM
    #60
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    the same, OME 886, OME Nitros all around, 1.5" AAL + 2nd toyo leaf swapped for chevy OMD!
