If You Had To Do It All Over Again, Would You Lift Your Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fxntime, Dec 17, 2017.
  1. Dec 18, 2017 at 7:40 AM
    #41
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    If the Toyota engineers find it acceptable to run the front end with 2” of lift (Bajas and Pros) then so do I. WRT the rear, the only delitirious effect I can think of is dealing with vibrations which isn’t exactly rocket science to fix.
  2. Dec 18, 2017 at 7:58 AM
    #42
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Yes I would, although the lift I have is fairly minor in comparison to most around here. 1.5" in front and 1/2" in the back from one size bigger than stock 265/75/16 AT tires and 3rd gen TRD suspension. Was the perfect and most economical solution to replace 10 year old worn out suspension. Personally I think this is the stance all Tacoma should come from the factory.
