? If you have a reg cab and flipped your driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by especk, Apr 14, 2011.
  1. Apr 14, 2011 at 10:18 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    When I let off the gas while going over 60 mph I get that weird grinding noise on my reg cab. I know a lot of people with reg cabs have fixed this problem by flipping their driveshaft (back to front/front to back).
    HAVE YOU EXPERIENCED ANY PROBLEMS AFTER DOING THIS? YES I'M YELLING. THANKS!
  2. Apr 15, 2011 at 2:43 AM
    JWare
    JWare Member
    Bolton, MA
    265/75/16 Treadwrights, Spidertrax spacers, WeatherTechs, Back-rack, Kobalt toolbox
    did it a few months back... Seems to have solved the problem for now.
  3. Apr 15, 2011 at 3:23 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    I did this after toyota replaced by rear differential assembly (This didn't fix the problem but I got a new diff at 67k :). Fixed the problem flawlessly. I'm at 80k and haven't had any problems since.
    JSYK the problem happened after I put a lift on my regular cab.
  4. Apr 15, 2011 at 5:18 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Virginia
    '06 RC, 4X4, 5 speed
    I'm stock and have the same issue as described. I flipped my driveshaft and it got rid of the grinding sound, but caused a lot of other uncomfortable vibrations. Flipped it back to normal after a week. This is not typical of others' experiences, so the flip may work for you. There's really nothing to lose by trying it. I would suggest using whiteout to mark the flanges on each end so you can line it up again in case you don't like the flip, and make sure to torque the bolts to the proper spec as you know.
    BTW, I did this at ~18,000 miles about two months ago. Oddly enough, after I flipped it back to normal, the grinding sound went away for about 3 weeks until I took the truck down some field-roads behind my house to work out the 4WD components. Also noticed that the slip yoke has verrry slight play in it.
    I plan to put up with it until I can get a double-cardon driveshaft in a year or two.
  5. Apr 15, 2011 at 6:50 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    18k in ~5 years?! Wow. :)
    Unless you didn't edit your stats...the pic in your sig looks like a 2011. :p
  6. Apr 15, 2011 at 10:35 AM
    especk
    Erik
    Redding, CA
    Thanks for the responses. This definitely sounds like something I will be doing.
    After the flip, the narrower part of the driveshaft looks like it will be more susceptible to being damaged on rocks and stuff. Did this ever concern any of you?
