If you have a supercharger, VISUALLY check your intercooler coolant!!!
Discussion in 'Performance and Tuning' started by inwood customs, Jan 4, 2017.
  1. Jan 4, 2017 at 5:27 PM
    inwood customs
    inwood customs [OP] Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    UPDATE
    ******TOYOTA LEFT A PLUG IN THE HEAT EXCHANGER*****
    Well, today I had some time to replace the hose I thought may have some internal blockage due to it being the only 1 I could see with a 90 degree bend. I had a spare I just bought and upon removal, I was greeted by a plastic PLUG in the heat exchangers INLET!!!!
    I paid toyota $800 to do the blower install so i wouldnt have to worry about screwing anything up!
    HERES THE UPDATED VIDEOS
    plug in the heat exchangers inlet
    https://youtu.be/2KFV9LdG2sw
    The truck put back together with the PLUG REMOVED and coolant cycled/purged of air
    https://youtu.be/koPD24qjJGE
    *****following vids are older and before I found the problem, good for comparison tho****
    heres a couple videos of mine,
    1st one you can see me over by the grille to show you the pump motor is "running" and then I show the reservoir barely, barely, barley moving any fluid.
    2nd video is after I siphoned out some coolant so it was below the return line in order to see how much, if ANY coolant was being brought through the system..... a TRICKLE
    https://youtu.be/RL4Pl6JDVt8
    https://youtu.be/3eUf-VMTCj8
    charcharias and Biscuits like this.
  2. Jan 5, 2017 at 8:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bad pump. Bad pump. Naughty. That pump is doing a lot of sucking, but not enough blowing.
    What's your solution, for the remedy?
    Need to take that pump apart to see what failed too. Money is on the impeller breaking off of the shaft.
    This problem right here is a defined path to non-cooled intake charge air. Which would then lead to :boom:
    ChadsPride likes this.
  3. Jan 5, 2017 at 9:24 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Is it hard to source a pump if it's bad?
  4. Jan 5, 2017 at 10:52 AM
    inwood customs
    Dave
    I ordered a pump for a gt500, and also found a pump with the matching trd#......which still had a bosch part# on it, so i crossed the bosch number, and got that one too.
    Toyota wants almost 500, cross referencing the number got me the same bosch for 93 bucks, ill provide a link AFTER i know it fits. I dont wanna send people the wrong info.
    Ill def be tearing into the old one.
    Luckily its been cold for a couple months, andni dont drive to nutty.... but im nit sure exactly how long this was an issue. No pinging that i can hear..... but thats not making me feel great.
  5. Jan 5, 2017 at 10:54 AM
    inwood customs
    Dave
    It took a few hours to source, even the dealership had no clue, until i found the trd # for him... and the parts guy is a friend and i have faith in his effort....
    In the end, Amazon
  6. Jan 5, 2017 at 10:56 AM
    inwood customs
    Dave
    Toy part# ptr29-35062
    $265 from Amazon.... 400ish from my buddy...500 list
    Cross reference the part number labeled on the side of the toyota one (find a pic), and it can be had for 93 bucks. If its indeed the same.
    Funny, its also a "rover" and ford part
    That said, ill provide a direct link once ive tested it.
    If anyone does this ln their own, be warned its just an idea i had using the oem pumps picture.
  7. Jan 5, 2017 at 12:09 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @Torspd Didn't we discuss putting a larger pump in at one point. What was the conclusion? Not worth it unless you drop a good penny for over twice the flow or something like that?
  8. Jan 5, 2017 at 12:10 PM
    inwood customs
    Dave
    Id like a better pump (petco here i come), and Coupes custom resi
  9. Jan 5, 2017 at 12:15 PM
    VolcomTacoma
    Jeff
    NorCal
    Nah a year or so again it was a topic for discussion and someone (@Torspd) did the research. Found a way better pump but I wanna say it was a couple hundred at least. Can't remember the details off the top of my head
  10. Jan 5, 2017 at 12:16 PM
    inwood customs
    Dave
    I was only half kidding.... the discussions been on xru yrs ago
    Torspd likes this.
  11. Jan 5, 2017 at 12:17 PM
    VolcomTacoma
    Jeff
    NorCal
    No but for real, you can get a 5GPM tank pump for like 59.99. Good call.
  12. Jan 5, 2017 at 12:27 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    The pump I got with my TRD kit is the exact same as the one with my Rousch kit. Can't be anything special?
  13. Jan 5, 2017 at 12:31 PM
    inwood customs
    Dave
    Nope.... in the end, everyone takes shit off a shelf.
    Its rare that anyone is gunna be asking for some special made pump if they can plumb in something off the shelf. Its just how things go.
    Im curious how much the bosch pump is from land rover.
    Torspd likes this.
  14. Jan 5, 2017 at 1:05 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Checked mine......all good, good swirl/movement/flow. Still am interested in the most affordable part number to have ready for when this one goes....
    inwood customs[OP] likes this.
  15. Jan 5, 2017 at 1:13 PM
    inwood customs
    Dave
    Ill update.... should be here tomorrow sometime. I also ordered some silicone tapered plugs just in case the coolant starts puking from the lines, i can plug em ....i dont want a ton of air bubbles to have to purge
    JuanitoBonito[QUOTED] likes this.
  16. Jan 5, 2017 at 1:19 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Don't overreact. I've driven without pumping several months, even at summer, before I got the wiring ready (switch for the pump that I can turn it off at wintertime.
  17. Jan 5, 2017 at 1:22 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Did you use human blood for coolant?
    bryanjoh, Torspd and JuanitoBonito like this.
  18. Jan 5, 2017 at 1:25 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    This outta be interesting....
  19. Jan 5, 2017 at 1:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rofl:
  20. Jan 5, 2017 at 1:35 PM
    inwood customs
    Dave
    I figured warm air, plus compression with a byproduct of heat, plus compression ratio, with a run thru death valley towards the end of last year... well, could have been bad.
