If you haven't serviced your 5-speed Auto Trans yet...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Aug 25, 2016.
  1. Aug 25, 2016 at 4:46 PM
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Hey I just completed the 60,000 mile service on my Tacoma (2013...DCSB...v6...SR5...4x4...5-spd Automatic).
    The service manual suggests servicing some components only if driving off-road, towing, or using the truck for otherwise heavy-duty applications. Being a service manager at our Ag equipment business, I usually decide to perform all (more than necessary) services on-time & at their scheduled intervals.
    Ok, here's what I'm getting to... One of the suggested services was to change the transmission fluid. I'm not 100% sold on a complete pressurized flush of the transmission. If you want to help convince me that it's a good idea, and will lengthen the usable life of the transmission, I'd really like to hear your input.
    Anyway... I drained only 2.6 qt. of the WS trans fluid out of the pan. I'm tempted to say that the truck was low on transmission fluid straight from the factory. I added more than 3 qt. by the time the fluid level was correct (followed the guide here on tacomaworld!!). My truck drive/shifts SO MUCH smoother now. I'm getting much less abrupt shifts, smoother downshifts, and an overall much better driving experience. When the torque converter unlocks, the power transition is smooth and gradual. No more lurch on converter lock/unlock. No more shudder during heavy-footed driving shifting. This is great!
    If you haven't serviced your 5-speed Auto Transmission yet...do it already. You'll be happy you did.
    Crom, ChadsPride, NateMob and 3 others like this.
  2. Aug 25, 2016 at 5:39 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Pretty sure at my dealership they dont recommend a full flush of the tranny. Just a drain and refill, like you did. Acura is the same way with their autos. Hydraulic flush can cause problems.
    Pretty sure my fluid is probably low too. During cold winter months my tranny tends to slip a little until warmed up. I think there is a thread on low tranny fluid from the factory.
    robssol likes this.
  3. Aug 25, 2016 at 5:58 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Yes I am planning on doing this in the near future, I have a 2009 4x4 with less than 40k but I do not like the way it shifts, (maybe it is low on fluid) Question? (I am not going to flush the entire system) so do I just drain & then fill until it comes out the overflow? Thanks
  4. Aug 25, 2016 at 6:21 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    My tranny fuild flush report
    asuchemist likes this.
  5. Aug 25, 2016 at 10:29 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Anyway... I drained only 2.6 qt. of the WS trans fluid out of the pan.[/QUOTE]
    I drained 3.0 qts. from an A750E-2WD transmission. Maybe you were .3 qts. low. Next time, after you drain the pan, elevate the front of the truck with a floor jack as high as it will go. You should drain another qt. of transmission fluid.
    gonathan85[OP] likes this.
  6. Aug 25, 2016 at 10:45 PM
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    I've been wanting to do the drain and fill but I remember when I had my last Chevy truck I did a tranny flush and it ended up shifting harder and worse. I was told that it was doing that because ATF gets thick with the clutch material mixing with the ATF so it gets a lot thicker than regular ATF and helps fill in the gaps between the gears. And when I replaced the thicker fluid and put new ATF in it started shifting harder because the fluid was thinner... So I'm hesitant to do this with 95k on the odometer because I don't want the transmission to shift hard it's had one flush done since new but shifts firm due to all the weight of armor and shell and 33"s think this would be good to do or just leave the fluid?
  7. Aug 26, 2016 at 12:16 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I had my mechanic (personnel) flush mine at 80k (took 14qts) following the tutorial on here, I run 33's in the summer and 265's winter with TJM bumper and ARE cap, with 130k now I haven't had any problems with the shifting or anything.
  8. Aug 26, 2016 at 12:33 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Yeah, but...
    Chevy!
  9. Aug 26, 2016 at 12:35 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Subb'd
  10. Aug 26, 2016 at 3:58 AM
    Jmad1997
    Is there a write up for drain and fill on the 4x4 transmissions?
  11. Aug 26, 2016 at 5:50 AM
    5.0 Hatch
    5.0 Hatch Well-Known Member
    I had mine changed at 100k against my better judgement and it is does shift a bit jerkier especially on the downshift back to 1st. It was done by the dealer and was only $150 so I doubt it was a full flush.
    Just my experience...
  12. Aug 26, 2016 at 5:56 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Pat Lob dealership in Texas said they do use the machine to flush the tranny fluid. So unless the service writer was wrong on the process which he shouldn't be since he sells the service. He also mentioned it is a world standard fluid not needed until 100K miles. I am currently at 65K.
  13. Aug 26, 2016 at 6:10 AM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
  14. Aug 26, 2016 at 6:25 AM
    moondeath
    Pa, Gardners
    You said you already flushed it once. So yiu are on track with the regular maintenance.
    In my tacoma maintenance manual it states to change the auto tranny at 60k miles.
  15. Aug 26, 2016 at 6:54 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I did mine at 30K. 12 qrts of Maxlife ATF.
    Crom likes this.
  16. Aug 26, 2016 at 8:12 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Believe me... just because they sell the service doesn't necessarily mean they know wtf they're talking about.
  17. Aug 26, 2016 at 8:15 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    100k is the old service interval. Toyota dropped it to 60k somewhere between 2009 & 2013. I drained 3.25 out mine when I did it
    moondeath likes this.
  18. Aug 26, 2016 at 8:39 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    The Good
    I just did a drain and fill last weekend at 51K miles. My truck is shifting much better now too!
    The Bad
    Only 2.5 qts came out and that's after jacking up the front of my truck to get more fluid out. I ended up being over a Qt low.
    The Ugly
    I set my torque wrench to 20lbs to tighten the drain plug and stripped that sumbitch! Camelback Toyota hooked me up with a new pan and plug so I will be doing another drain and fill this weekend and putting the new parts on. Be careful tightening the drain plug, 20lbs is apparently the "dry" spec and I probably should have set it to about 12lbs. I will snug it without a torque wrench this time and go by feel like I do on my oil drain plug.
  19. Aug 26, 2016 at 9:16 AM
    stump jumper
    Bill
    Texas
    I set mine to 20 but as soon as I felt it getting snug I quit tightening.
  20. Aug 26, 2016 at 10:22 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Torque wrench failed me as well. With the low torque requirements I just tighten with a smaller ratchet like I do with the oil pan drain bolt
