If you own a 2017 Tacoma you need to check...
Discussion in 'Arizona' started by SCUBADIVINGJOE, Dec 29, 2022.
  1. Dec 29, 2022 at 10:54 AM
    SCUBADIVINGJOE
    SCUBADIVINGJOE [OP] Well-Known Member
    Mark
    2017 Toyota Tacoma
    Seat covers, LED Low Beams, LED FOG Lamp, Dash Cover, Pop and Lock Tailgate, Tuffy Security Console Insert, Steel Nerf Bars I want to add Hood QuickLIFT ELITE Gas Struts and High Beam LEDs
    Take a look at this thread:
    https://www.tacomaworld.com/threads/another-timing-chain-cover-leak.556242/page-5
    My 2017 has 65,409 miles on it. My battery was going bad for the second time and it was under warranty so I took it into the dealer for a replacement battery. Well guess what. Mine is also leaking. Under extended warranty. They said the cost will be ~$4000 to fix. Best way to fix is pull the motor.
    Have anyone else here had this problem?
  2. Dec 29, 2022 at 4:57 PM
    GilaTrails
    GilaTrails Well-Known Member
    Champaign IL / Safford AZ
    2018 Inferno Tacoma TRD Offroad
    Matching Colored Tire Valve Caps
    $4000 for a leaky battery?
    whatstcp and drizzoh like this.
  3. Dec 29, 2022 at 4:58 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Timing chain cover lol, but it's not worded well.
  4. Dec 29, 2022 at 5:07 PM
    GilaTrails
    Looks like you can get entire crate engines for 4k.
  5. Apr 5, 2023 at 1:37 PM
    UTAH GetMeTwo
    UTAH GetMeTwo Well-Known Member
    Cave Creek, AZ
    21 4RUNNER ORP KDSS
    '17 Tacoma - No noticeable leaks at 67,500, but developed substantial leak by 75,000. Timing cover seal, rear main seal, and rack & pinion leak. Full motor-out repair for seals and full rack/pinion replacement. Quoted about $9k at Camelback Toyota.
    Sad to say I traded her in... the 4Runner got promoted to daily driver.
    Good luck out there gentlemen (and ladies).
