If you want it done correctly, do it yourself
Discussion in 'Suspension' started by whitebread, Mar 10, 2010.
  1. Mar 10, 2010 at 6:25 AM
    whitebread
    whitebread [OP] Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    My plan was to install my lift kit myself, but as I got into it, I kept running into headaches. My jack stands were too short, had a hell of a time getting the ball joint apart, my spring compressor (made for VWs) didn't fit on the coils, etc. I decided it was just going to be easier, and quite possibly cheaper, to pay a shop to install my OME kit rather than fuss with it myself.
    I researched shops in the area and got quotes...settling on one that specializes in off road trucks and had an impressive completely custom first gen taco of their own.
    I should have done the suspension mods myself. :frusty: When backing up or braking hard I would hear a "click." I thought it might be my sway bar hitting the struts, so I put in my relocation bracket. It still did it. So when I got home last night, I grabbed the upper control arm and yanked it it. It wiggled and made that same clicking sound! The long bolt that fastens it to the chassis was just hand tight!!! Literally hand tight. The torque spec for that fastener is 85 ft*lbf. I checked the other side and it was tighter but the wrench readout was showing about 60 ft*lbf, not the correct 85 ft*lbf.
    I re-torqued them to the correct spec but now am wondering what else is messed up. I am going to have to go through and check all their work. :rolleyes:
    [In my day job I have the joy of calculating fastener torque values for our products and understand from a theoretical perspective why the torque values are not arbitrary and are detrimental to the function of the joint. Just tightening something down until it is 'probably good enough' is not acceptable in my book.]
    Just a warning to others...if you want it done correctly, do it yourself.
  2. Mar 10, 2010 at 6:33 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Yep...yourself is always the best way so you know it is done right.
  3. Mar 10, 2010 at 6:36 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Well...At least checking it all over should be easier to do with the tools you have.
    Glad you figured it out before anything departed the truck or seriously failed.
  4. Mar 10, 2010 at 6:39 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    did you have the UCA's changed? if not, why did they even fuss with them?
  5. Mar 10, 2010 at 6:39 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    that is why i dont ever let anyone touch my shit
  6. Mar 10, 2010 at 6:47 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Yes...I will be the only one doing non-warranty work from now on. :p
    Yup, the SPC Light Racing UCAs, which by the way I am extremely impressed with. The online product literature doesn't do them justice. Serious adjustability.
  7. Mar 10, 2010 at 6:53 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    always have always will
  8. Mar 10, 2010 at 7:06 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Your truck looks great after the lift. I'm looking to do something like that to my truck but haven't really decided what I want yet. What kind of lift did you buy? How much lift? How much did the lift itself cost you?
  9. Mar 10, 2010 at 7:21 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Thanks. I went with the OME kit w/885 coils and an AAL, LR UCAs, then also added new U Bolts, extended rear brake lines, and the sway bar relocation plate (probably not needed?). Parts ran $1198 plus shipping from ToyTec with the TW discount. At the same time I went to 265/70-17 Goodyear Wrangler DuraTrac tires.
  10. Mar 10, 2010 at 7:31 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i'm just glad you made it home without everything falling apart
  11. Mar 10, 2010 at 7:32 AM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Sometimes you might think the job is too much for you, it may just require you to seek additional knowledge or assistance. Keep these in mind:
    From your point of view: I like my vehicle, and want to do this right the first time. I take pride and satisfaction in a job well done. :)
    From an outside source: Just another filthy vehicle to bust my knuckles on, they don't pay me enough for this BS! WTF, I never did this before... No sweat, I get paid by the hour. :frusty:
    Good mechanics are out there, so when you finally find one, always be sure to tip them in cash or beer, and stick with them. They may not be easy to find, and will not be the cheapest cost, but in the end the cheapest in not the least costly. :cheers:
  12. Mar 10, 2010 at 7:59 AM
    MAXTacoma
    Lexus GS 350
    Thanks for the information... Your truck looks great, thats about the height that I'm looking to get. Does your truck still fit in the garage with the lift?
  13. Mar 10, 2010 at 8:17 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Sorry you had troubles. The auto repair trade drives me crazy. Paid on time more than quality. There is never time to do it right but there is always time to do it over! Your comments about torque values is spot on. Those that tighten with air tools or German torque values (gootntight) cause more trouble down the road. On top of that, not tightening to specifications is shortcutting the job, so you are NOT doing the job you are being paid for (by book time). I am a tech and I even torque drain plugs! But you know what? 250K mile cars that I service, I can put a wrench on the drain plug, loosen it 1/4 turn and take it out with my fingers. It saves me time in the long run. On top of that it saves my customers money. The only oil drain plugs or pans I have had to replace are on vehicles that I have not regularly serviced.
    Developing a relationship with a good shop is important. Many times people develop a relationship with the service advisor and that is not bad. I would encourage you to speak with the tech working on your vehicle. If you find a good one, the best tip you can give them is likely to REQUEST that tech when you schedule. It helps develop a partnership. If the shop you use does not like you talking with your mechanic.........ask why ;)
    Some shops and owners fear that a tech could leave and take customers with them. If they have turn over that high, I think it says something........
  14. Mar 10, 2010 at 10:08 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    All great info, thanks!
    Neil, yes it still fits in the garage, but only by a gnat's whisker. There is a rubber weatherstrip/seal on the door frame that seals against the garage door when closed...that hits the bars on top of my rack. And the radio antenna hits by a good inch or so and I have since ordered a shorter 13" antenna.
  15. Mar 10, 2010 at 10:18 AM
    MAXTacoma
    Lexus GS 350
    Well thats good to know bc I wouldn't put the lift on if my truck didn't fit afterwards. Its a must that I park my truck in the garage! Thanks for your info!
