If your wheel's center bore is 106.1 you do not need hub centric rings?
Discussion in 'Wheels & Tires' started by hoodwinked, Jan 21, 2025.
  1. Jan 21, 2025 at 5:59 PM
    hoodwinked
    hoodwinked [OP] Well-Known Member
    Couldn't find a definitive answer. The wheels I am looking at getting have a 106.1 center bore. Since it's a perfect match for a 3rd gen Tacoma, I do or do not need rings to make sure the wheel is centered? I am correct to believe rings don't exist for this circumstance since the center bores are the same?
    It does not say on the manufactures site if the wheel is hub centric or lug centric.
    I have these lugnuts currently:
    https://westcoastacc.com/product/32...ne-ET-Lug-Nuts-1.55in-6-Lug-Install-Kit-Black
    Looking at getting these wheels:
    https://www.bbwheelsonline.com/pro-...7x8-6x139.7-matte-black-20mm-pa200mx17806820/
    Thank you!
  2. Jan 22, 2025 at 8:22 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Nope, bolt up with the correct nuts and go.
    gotoman1969 and drizzoh like this.
