IFS Doublecabs on the Rubicon??? You bet.
Discussion in 'Off-Roading & Trails' started by sixstringsteve, Apr 3, 2014.
  1. Apr 7, 2014 at 2:09 PM
    #41
    sixstringsteve
    sixstringsteve [OP] Well-Known Member
    For the right price I would sell it, but it's not listed at the moment.
  2. Apr 7, 2014 at 2:11 PM
    #42
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    oh i was just wondering i swear i saw an add on rme for it.
  3. Apr 7, 2014 at 3:19 PM
    #43
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    285/70R17
    And 3" OME suspension lift - I sorta figured that went without saying :eek:
  4. Apr 7, 2014 at 3:21 PM
    #44
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    slickrock is conventionally reckoned to be *mucho* easier than rubicon.
  5. Apr 7, 2014 at 3:22 PM
    #45
    sixstringsteve
    You'd be great, especially with the short wheelbase. That's the same tire size the other two guys had on their rigs, and they did awesome. I'd say your truck is plenty capable if you have the driving skill.
    Is yours an auto or a manual?
  6. Apr 7, 2014 at 3:24 PM
    #46
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As you say then, just a matter of racking up enough off-road experience. Not there yet either. :cool:
  7. Apr 7, 2014 at 3:25 PM
    #47
    sixstringsteve
    fwiw, we turned on our front lockers maybe twice for the trip. We would have been fine without them (except we would have been left with the weak stock spider gears). If a vendor sold aftermarket cromo replacement spider gears, we would have installed those instead of ARBs.
  8. Apr 7, 2014 at 3:27 PM
    #48
    sixstringsteve
    I see you have a 5 speed. The first time I ran the rubicon was in a standard cab 5-speed, but I had dual cases in it, which made a world of a difference. It's definitely trickier in a 5-speed with stock gearing in both the t-case and axles. Then factor in the larger tires and it gets even harder to crawl slow.
    I'd recommend learning how to crawl with the clutch all the way out, then just use the throttle to keep it from stalling. A lot of noobs slip the clutch over and over with each rock or obstacle (and I don't blame them if they're new to wheeling). Don't do that, you'll just fry your clutch and get frustrated. Just let the clutch out in 1st in 4-lo, no throttle, then use the skinny pedal to keep it from dying when you get on a rock. I'm talking minimal RPM, like almost stalled but you saved it. To me, that means running at 500-700 rpm with zero throttle, then giving it a little gas to keep it from stalling (still keeping it under 1100-1300 or so when you get to an obstacle). Easier said than done, but it'll save your clutch and teach you how to crawl better.
    If you get dual t-cases (which I wouldn't recommend unless you do a lot of crawling), it only gets cleaner and smoother and easier. With duals, you can let the clutch out without the gas pedal at all. I wish my current truck had duals and a 5-speed, but I don't crawl enough anymore to justify the cost.
  9. Apr 7, 2014 at 3:30 PM
    #49
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm geared a little lower than stock at 4.88.
    And yeah, I try and keep it all the way out when possible. I've been known to feather it a bit over obstacles tho. :eek:
  10. Apr 7, 2014 at 3:34 PM
    #50
    sixstringsteve
    You're truck is plenty capable enough for the Rubicon Trail. Just keep wheeling and getting the experience under our belt 'till you feel ready. You'll learn how your truck likes to climb and descend different things, and eventually the two of you will speak each others language and you'll know exactly what will happen before, during, and after each obstacle.
    I guarantee everyone is a better wheeler at the end of the rubicon than when they started the trail. :) And that's not to say you have to be an expert to run the trail, plenty of noobs have done it. However, a seasoned driver will know which line to pick, when to compression brake vs use the pedal, when to bump it and when to crawl it. A seasoned driver will get your rig through without any scratches, body damage, or straps/winching.
    Fortunately the trail gradually gets tougher and tougher (when you start at loon), so if you get in over your head, turn around and go back.
  11. Apr 7, 2014 at 4:03 PM
    #51
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Good to know! Ill start there then, get some seat time before attempting the Rubicon! :D
    Thanks man!
  12. Apr 7, 2014 at 4:09 PM
    #52
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    At some point earlier this spring some folks were agitating around doing hell hole jeep trail sometime - that might be a fun one to plan a tw run for sometime this summer too.
  13. Apr 7, 2014 at 4:18 PM
    #53
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Awesome video, i am digging the soundtrack.
  14. Apr 8, 2014 at 12:37 PM
    #54
    sixstringsteve
    Thanks. Good music can make a boring video a lot more exciting to watch.
  15. Apr 8, 2014 at 12:49 PM
    #55
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This looks FANTASTIC! I will have to come here one day. Ahh.. One day.
  16. Apr 8, 2014 at 12:53 PM
    #56
    sixstringsteve
    Living in Concord, you're under 3 hours away. I envy you. :)
  17. Apr 9, 2014 at 11:59 AM
    #57
    marintacoma
    marintacoma Well-Known Member
    Marin
    2004 white toyota tacoma 4x4 trd
    i noticed the 35s seemed to roll over obsticles pretty easily, and the smallest anyone ever runs seems to be 33s. wonder if a fairly stock truck with 265/75/16 would have a lot of trouble... would definitely get sliders first
  18. Apr 9, 2014 at 12:14 PM
    #58
    sixstringsteve
    Not knowing your driving experience, I would strongly recommend against it. Can it be done? Sure, I'll bet somebody's done it once, but I'm guessing they were expert drivers. If you don't have sliders yet, I'm going to assume you don't have a ton of rock crawling experience, and this is not a good first trail. The Rubicon is a fantastic trail, but not a good trail to cut your teeth on rock crawling.
    While you may be comfortable running it in your current condition, remember that breakage or failure impacts others who are using the trail. There are sections of the trail that if you break down, you stop traffic for people going both ways. That's not to say a breakage is always inconsiderate, but attempting a trail you're not prepared for is. My friend ran the Rubicon with us, and rolled his rig. It clogged traffic both ways for 3 hours. The rest of the people behind him were NOT happy.
    Work your way up to it. I highly recommend you get this book and drive a handful of trails starting with the easiest, then working your way up to the Rubicon.
  19. Apr 9, 2014 at 12:27 PM
    #59
    marintacoma
    Marin
    Wasn't planning on tackling the rubicon as my first trail, but definitely will be out exploring around the rubicon area on some easier trails first. Are there any easier trails in that area that you would recommend?
  20. Apr 9, 2014 at 12:28 PM
    #60
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    Nice vid!
