IG1 10a fuse blowing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyotalady, Feb 8, 2019.
  1. Feb 8, 2019 at 4:05 PM
    toyotalady
    toyotalady [OP] New Member
    2008 Tacoma 4.0 V6 manual
    My 2008 Tacoma is repeatedly blowing the "IG1" 10a fuse. When it started, the VSC started flashing and the CEL and car with the squiggly lines behind it symbol light came on solid. The speedometer and the turn signals stopped working, too. I've replaced the fuse several times in the last week. The first time I drove 1.1 miles and all was normal. Started it up again and the fuse blew. I borrowed a friends code reader and it has a P0500 code. This last time I replaced the fuse my turn signals and speedometer were working but the VSC, CEL, and the squiggly car stayed on. I only drove for about 2 miles after replacing the fuse. Any help would be greatly appreciated.
  2. Feb 8, 2019 at 4:34 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Any modifications to the truck?
    Lester Lugnut likes this.
  3. Feb 8, 2019 at 4:44 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    '15 Tacoma PreRunner V6 SR5 Auto
  4. Feb 8, 2019 at 6:29 PM
    toyotalady
    no mods just slightly larger tires than stock done 4 yrs ago.
  5. Feb 8, 2019 at 7:38 PM
    hemitruk
    hemitruk Well-Known Member
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    Tundra Racing drop ,12 up front conversion and some
    Need to find out what circuits run off that fuse . Working on a 05 rav4 blowing gauge fuse . Ac and blower, 3 pass windows, rev lites , speedometer all not working not to mention vss, trac and check engine lite on. because of gauge fuse .Kind of crazy how different circuits connected to that one fuse . Owners manual will tell you what runs off of each fuse .
    Found wiring diagram on ebay so now time to trace down wiring .:facepalm:
  6. Feb 9, 2019 at 6:49 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    hemitruk likes this.
  7. Feb 10, 2019 at 10:43 AM
    toyotalady
  8. Feb 10, 2019 at 1:44 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    From the diagram posted, it seems like the ign1 fuse is involved in a lot but notably, TRAILER TOWING. I wonder if you have salt and wet slush in the trailer socket if you are so equipped.
    Jimmyh likes this.
  9. Feb 11, 2019 at 6:30 PM
    toyotalady
    The trailer socket was exactly where we went on Saturday. Found a small amount of dirt in there, blew it out, put in a new fuse and VOILA! Hasn't blown the fuse since. Thank you all for your input.
  10. Feb 11, 2019 at 6:45 PM
    Troyken
    NY
    I'm glad it worked out for you. That salty conductive mess is a disaster.
