IG1 Fuse BLOWS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boomer6, Sep 18, 2011.
  1. Sep 18, 2011 at 7:25 PM
    boomer6
    boomer6 [OP] Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Was wondering if anyone has a fix for the Ig1 fuse that keeps blowing. Blows when I go to put it into reverse.No mods yet. Its a 2011 with only 697 miles on it.Have gone through ten 10amp fuses so far.Any suggestions?
  2. Sep 19, 2011 at 6:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Probably has a pinched wire somewhere since it's a brand new truck. Other than looking for obvious signs of damage from being transported to the dealer or something like that, I would just take it back and let it be the dealer's problem.
