IG1 Fuse Keeps Blowing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexchoate75, Oct 2, 2024.
  1. Oct 2, 2024 at 8:33 AM
    Alexchoate75
    Alexchoate75 [OP] Member
    Alex
    2008 Tacoma TRD Sport V6
    2008 Tacoma TRD Sport V6. Factory tow package. I hitch up, plug in my 7way, check all my lights(all are good) and as soon as I take it out of park I blow IG1 fuse. I thought there might be a problem with the trailer wiring but I hook up to 2 other vehicles and all is well. Can someone help?? Thanks!
  2. Oct 2, 2024 at 10:03 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Does it blow with no trailer connected?
    If it doesn't blow with the trailer disconnected the issue is more than likely in the trailer wiring or in the 7 way connector. NOTE: This connector is a common problem item due to the constant exposure to the elements.
    TS4x4 likes this.
  3. Oct 2, 2024 at 10:08 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Loads on the IG1 Fuse 10 Amp:
    ABS (w/ VSC), TRAC, VSC, Auto LSD, Downhill Assist Control and
    Hill–Start Assist Control
    ABS (w/o VSC)
    Accessory Meter
    Air Conditioning
    Back–Up Light
    Charging
    Combination Meter
    Cruise Control (1GR–FE)
    Cruise Control (2TR–FE)
    Electronically Controlled Transmission and A/T Indicator (1GR–FE)
    Electronically Controlled Transmission and A/T Indicator (2TR–FE)
    Engine Control (1GR–FE)
    Engine Control (2TR–FE)
    Headlight
    Multi Mode 4WD and Rear Differential Lock
    Power Outlet (115V
    Rear Differential Lock (2WD)
    Seat Belt Warning
    Shift Lock
    SRS
    Tire Pressure Warning System
    Trailer Towing
    Turn Signal and Hazard Warning Light
  4. Oct 2, 2024 at 10:29 AM
    Alexchoate75
    Alex
    Jimmy, No it does not.
    Jimmyh likes this.
  5. Oct 2, 2024 at 10:36 AM
    Alexchoate75
    Alex
    Also, Jimmy, I hooked up to both of my other vehicles and pulled the trailer fine without issue(2019 Ram 3500 and 2020 4Runner TRD Pro).
    Jimmyh likes this.
  6. Oct 2, 2024 at 10:41 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Something isn't wired correctly either on the truck or on the trailer or you have a short on the trailer.
    If you have the factory 7 way the only thing the IG1 fuse feeds on the trailer plug is the reverse lights (which most trailers don't even have).
    This is how a standard 7 way plug should be wired (note colors may vary but pin designations are always the same).
    Too Stroked, Jimmyh and TnShooter like this.
  7. Oct 2, 2024 at 10:47 AM
    Alexchoate75
    Alex
    Dm93, what still doesn’t make sense is that it’s only blowing the fuse on my Tacoma. I pulled out both tail light assemblies looked for shorts and tested all circuits that I know to check.
  8. Oct 2, 2024 at 10:54 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Inspect the trailer plug and wiring on the Truck. It may have an issue that only shorts out when the trailer is plugged in.
    reallifedog likes this.
  9. Oct 2, 2024 at 10:54 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Take the plug apart on your trailer and see if anything is hooked up/touching the center pin, if it is then you need to trace that wire on your trailer and see where it goes.
    Jimmyh likes this.
  10. Oct 2, 2024 at 10:56 AM
    Alexchoate75
    Alex
    Thanks guys…I’ll do that now.
  11. Oct 2, 2024 at 11:48 AM
    Alexchoate75
    Alex
    I didn’t find anything out of sorts.
    More context: Trailer is 8.5x17 wired for 30amp with a batter and charge controller. Any chance this could just be more of a power draw on the Taco??
  12. Oct 2, 2024 at 6:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The 10 Amp IG1 fuse powers the backup lights via the Reverse Switch on a Manual Transmission and through the Park Neutral Switch Reverse contacts on an Automatic Transmission.
    If IG1 is blowing with the trailer connected and NOT when it is disconnected the issue is more likely an issue with the trailer. Are you using the same 7 wire connector on the trailer for the other vehicles that don't blow a fuse? Have you towed this trailer with the Tacoma before?
  13. Oct 3, 2024 at 3:54 AM
    Alexchoate75
    Alex
    Jimmyh, yes, it’s the same connector for all three vehicles and this is the first time to hook up to this trailer with this Tacoma.
  14. Oct 3, 2024 at 4:06 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Did you take a peek inside the housing at the actual spade connections? If it's green in there, you've probably found your problem. Same goes for the junction connector further back in the wiring harness.
  15. Oct 3, 2024 at 4:38 AM
    Alexchoate75
    Alex
    Too Stroked, that was one of the first things I checked. I didn’t see anything bad but went ahead and cleaned all the connections on the truck and trailer. And yes, it is the factory tow package with factory wiring.
  16. Oct 3, 2024 at 6:22 AM
    Too Stroked
    Tom
    That's good. You've eliminated one of the major causes of trailer wiring headaches. You wouldn't believe some of the "green gardens" I've seen in rarely used trailer connections.
  17. Oct 3, 2024 at 8:26 AM
    Alexchoate75
    Alex
    I have to be missing something…I can hook up, run through all the lights and as soon as I take it out of park THATS when the fuse blows. I’ve been through about 7 fuses now…chasing leads and retrying. I’m lost.
  18. Oct 3, 2024 at 8:32 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Has the wiring on the truck plug ever been messed with or the plug replaced?
    Would be the only explanation aside from the fault being on the trailer.
  19. Oct 3, 2024 at 8:39 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Try this as the power passes through the Park Neutral Switch reverse contact.
    Replace the fuse.
    Place the transmission in Neutral.
    Plug in the trailer harness 7 way connector.
    Then check the lights (without putting it in reverse) to see if the fuse blows.
    Possibly an issue with the Park Neutral Switch.
    Too Stroked likes this.
  20. Oct 3, 2024 at 8:48 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I might have missed it, but did you check the truck side? The 7-pin socket, or T12 as Toyota calls it on that pdf
