IGN tap from under/inside the engine fuse box
Discussion in 'Technical Chat' started by caribe makaira, Aug 5, 2016.
  1. Aug 5, 2016 at 1:50 AM
    caribe makaira
    caribe makaira [OP] Well-Known Member
    Caribbean, Puerto Rico
    Awaiting parts, but wanted to share...
    Wanting to keep things tight and neat, I thought of this: Use all spaces in the connector EB1: Which handles Alternator IGN sense source (Lime Green), Starting Coil (Yellow w/ Green Stripe), Generator Load sense (Gray) and Alternator Sense (White). There are two more empty slots which are the ones I.D.'d for IGN tap for added electrical mods.
    So making a mini harness and getting a one slot matching connector (M&F); this to remove the OEM male connector from its under location and inserting it into said connector, then inserting made mini harness to other side. On other side of mini harness are all male terminals, one to original location and two other ones to empty spaces in connector EB1. On the vehicle harness the plug would get two female pigtails to use for IGN mods.
    The fuse box has to be opened to access and install all this.
  2. Aug 8, 2016 at 10:27 PM
    caribe makaira
    More info still. Adding a relay to not task the OEM IGN circuit.
    Other spots that might be available
    Circuit and parts
    No need to fill all empty slots on added connector or on EA1 or EB1
    EA1 connector circuit Info
    EB1 info
    Empty slots in connectors
    Ground for relay info. 4 slots to chose. Need female to female pigtail for ground.
    Circuit to ground on that buss bar
    super_white likes this.
  3. Aug 8, 2016 at 10:28 PM
    caribe makaira
  4. Aug 22, 2016 at 8:27 PM
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
    sub'd
    Edit: Where do you buy the pins for those connectors or find the part numbers for them?
  5. Aug 22, 2016 at 11:26 PM
    caribe makaira
    Sumitomo TS / SL / DL 090 Unsealed Female Terminal 0.5 - 1.25 mm2 ( 20 - 16 AWG )@ bmotorsports.com
  6. Aug 23, 2016 at 6:41 AM
    will.carroll7
    Thanks! And what types of pins do you use for the relay contacts?
  7. Aug 23, 2016 at 11:43 AM
    caribe makaira
    For now, uninsulated .250 female terminals. Can't find the proper locking kind. Might go to junkyard and scavenge some.
  8. Apr 12, 2020 at 1:10 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Pick me up some, I'll pay ya.
  9. Apr 12, 2020 at 1:14 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I just took another walk out to the truck with my trusty Fluke 88V (I've had that thing for a good 15+ years).
    I found IGN at three terminals in connector 2B thats in the main under hood junction block. Now I'm looking through my EWD's to see what those terminals have in common.
  10. Apr 12, 2020 at 1:16 PM
    caribe makaira
    That was 2016...now I'm on house arrest due to Covid-19...:burp:
    crashngiggles likes this.
  11. Apr 12, 2020 at 1:45 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    2106?! :eek: My bad.
    I'm not under house arrest as I'm "essential" :cool:
  12. Apr 12, 2020 at 2:39 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Would you happen to know the part number for this terminal circled in white?
  13. Apr 12, 2020 at 2:52 PM
    caribe makaira
    No I do not, but a .250 spade uninsulated would fit on the other side...
  14. Apr 12, 2020 at 3:07 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Are they push to lock or pull to lock? Metripack 630 female terminals are pull to lock. Can be had at customconnectirkits.com. Push to lock are common relay female terminals and can be had at Amazon or O’reilly’s.
  15. Apr 12, 2020 at 4:34 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That's close to what I'm looking for. I was thinking that I could add a terminal/wire to the junction block in the are I circled in white and then add a micro fuse such as this: https://www.customconnectorkits.com/fmm-30/
  16. Apr 12, 2020 at 10:00 PM
    caribe makaira
    Sure...they are "slow" blowing. Lowest available is a 20 amp.
  17. Apr 13, 2020 at 1:18 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I would probably use a 50A fuse, one for each relay box. I also searched my EWD's and haven't seen what power those three IGN sources I found.
  18. Apr 13, 2020 at 2:37 AM
    caribe makaira
    Do you have a 4 banger?
  19. Apr 13, 2020 at 3:02 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Yes I do. Reg cab, 4 cylinder with no options.
  20. Apr 16, 2020 at 2:28 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Has anyone done this to eliminate fuse taps on the interior fuse panel?
