igniter and missfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by fboofs, Oct 29, 2021.
  1. Oct 29, 2021 at 6:30 PM
    fboofs
    fboofs [OP] New Member
    Gordon
    1995 toyota tacoma 4x4 3.4 v6
    none i guess
    hello everyone, i have a 1995 toyota tacoma with the 3.4 v6.. has like 200,000 miles and everything has been pretty good except like 3 monthes ago i had 2 change spark plug wires and then it was all good again..... now, like all of a sudden im getting missfire's.. codes read p0300 then p0301 - p0306 ... then came the i think its p1300 igniter #1 and igniter ... i dont know whats going on... im afraid its gonna be valves... but it happend so fast! any suggestion would be great thank you in advance.... Gordon Rowe .Grass valley, ca
  2. Oct 30, 2021 at 4:26 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Here we go
    Misfire detected at #1 and #6 possible causes to include.
    Bad spark plugs
    Bad spark plug wires
    Bad ignition coil or coils for #1 and #6, Unlikely both.
    Unserviceable ignition control unit.
    It can be valves but I wouldn't panic as of yet.
    It couldn't hurt to get a compression test to rule out the valves.
  3. Oct 30, 2021 at 4:37 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    I would go ahead and replace the ignitor coil. If the ignitor is faulty you will get random cylinder misfires.
    It could be valves. I wouldn't look there.. You said it ran good after wires. Does it run smooth, with good power and starts up fine?
    Let us know.. take care
  4. Oct 30, 2021 at 10:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The PO1300 means the ECM is not seeing the igniter signal it thinks the engine is not running so shuts off the fuel.
    What kind of shape are the spark plug boots on under the coils ?
    The spark Plugs ?
    Why only change 2 wires not all 3
    I doubt it is valves unless you never change your oil .
  5. Oct 30, 2021 at 10:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe time for valve cover and spark plug tube gaskets
