Ignition Coil Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by filby, Jan 16, 2024.
  1. Jan 16, 2024 at 2:29 PM
    filby
    filby [OP] New Member
    2018 Tacoma TRD Off Road
    None
    Hello all,
    First time posting in here. I have a 2018 Tacoma TRD Off Road.
    I saw a previous post in here similar to my issues but was confused by what came of it for end result.
    I have had numerous ignition coil issues since purchasing my truck back in 2019 (bought used with 17k) Now has 92k on it and I am having the same issues as before. Check engine light on as well as the trac off light. Truck tops out at 2000 RPM and idles rough. Shakes and vibrates. I had a scan tool hooked up to it and showed a misfire to cylinder 3 (P0303 code I believe) I examined the coil upon removal and it had some rust so I cleaned it off and put it back in and the truck ran fine for about 30-40 miles. Coming back home, the check engine light came back on as well as trac off. I limped it over to an auto zone and moved the coil to cylinder 5 and had them run a scan tool which showed misfire to cylinder 5 and showed a code P0305 along with other codes. This led me to think the ignition coil was the issue since it followed the cylinder.
    I purchased a single new ignition coil and installed into cylinder 5 (and have since moved it to cylinder 3) and its still idling rough and showing check engine light and trac off even after disconnecting battery for 5-10 min. Anyone else had an issue with their coil packs or have an idea what to do??
  2. Jan 16, 2024 at 5:48 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I’d swap 2 coils that you know work from other cylinders to 3 and 5. If the misfires move to the donor cylinders then you know those two coils are bad.
    MannyS likes this.
  3. Jan 16, 2024 at 8:44 PM
    Clappie
    Clappie Member
    Sacramento
    2019 Cement TRD Sport AT
    Look for carbon tracking on inside of coil spark plug boots and on spark plug porcelain.
  4. Jan 16, 2024 at 8:45 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Did you check the plugs ? If you saw “rust” the plugs are usually loose
