Ignition Coils?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rock Miner, Jul 14, 2018.
  1. Jul 14, 2018 at 1:05 PM
    Rock Miner
    Rock Miner [OP] Member
    Spanky
    Florida
    2014 Prerunner 4.0 and 2020 SR5 3.5
    First of all, Thanks for all the info you share. I've been a peeping Tom on the site for a few years and finally decided to get inside the window.
    Doing some PM at 269K on my prerunner 4.0. Along with several other items I'm changing the plugs for the second time. First time around I used the original ignition coils. Should I change them out this time or wait and change them as they falter?
  2. Jul 14, 2018 at 1:09 PM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    Well change them if you get a code for them, if they go bad they will cause a blown head gasket.
  3. Jul 14, 2018 at 1:15 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    An ignition coil causing a blown head?
  4. Jul 14, 2018 at 1:16 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Yup causes misfiring happened to me before on my 05, kept driving it.
  5. Jul 14, 2018 at 1:20 PM
    Bebop
    Nick
    I think the blown head probably caused the misfire. Not a coil causing the blown head.
  6. Jul 14, 2018 at 1:22 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Never have i heard of a bad coil blowing a head gasket
  7. Jul 14, 2018 at 1:25 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    The misfire causes hot spots which leads to blowing the head gasket. Thats what my mechanic told me.
  8. Jul 14, 2018 at 1:51 PM
    Bebop
    Nick
    Sounds like you need a new mechanic
    Lester Lugnut, blu92in99 and 757yotas like this.
  9. Jul 14, 2018 at 2:53 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Welcome. For $80-$120, it could be peace of mind for another 270k..
    Edit: Guess I was off base a bit, looks around $360 for 6 Denso 673-1308 off Amazon. I went 351k miles in my 07 4.0 Tacoma and never needed to change a coil, like others have said, wait til you throw a code to replace.
  10. Jul 14, 2018 at 9:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As Bebop said you need a new mechanic. That one is an idiot.
    Lester Lugnut and Bebop like this.
  11. Aug 7, 2018 at 8:05 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    How often should the ignition coils be changed? The manual doesn’t speak to them as far as I can tell.
  12. Aug 7, 2018 at 8:11 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    You change them when they throw a related code.
  13. Aug 7, 2018 at 8:52 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    when they stop working, you replace them o_O
    195k miles and running strong with factory original spark plugs and still getting 420 miles per tank :crapstorm:
  14. Aug 7, 2018 at 9:36 AM
    TheDevilYouLove
    Marylandistan
    I’ll prolly replace them at 200k, right now just under 130k. The Denso ones are about $80 each so I better start saving my pennies, lol
  15. Aug 7, 2018 at 9:52 AM
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    I wonder if there are any cross compatible coils. For example, back in the day my Focus required some pricey coils, I found I could use another Ford coil, can't remember the model of car but it was a direct fit.
  16. Aug 7, 2018 at 10:41 AM
    knottyrope
    Knotty
    Bahstun
    A guy on here went 400k miles with hardly any maintenance done.:eek:
    I am at 195k miles with not much done.:thumbsup:
    Go change your coils, plugs, antifreeze, diff fluid, trans oil, blinker relays, starter, water pump, alt, belts, u joints, brakes, hoses, brake fluid, freon, winter air, big boy pants and what ever else you can change at every oil change. :annoyed::deadhorse:
    I change nothing until its broken and have money in the bank along with a lot of free time on my hands.
    :rockband:
    :dancingbacon::kona::jellydance::bananadance::broccoli::taco:
    :yay::woot::yes:
    Tnronin likes this.
  17. Aug 7, 2018 at 11:04 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Like others said, the coils are not a regular service item. Run them until one fails or you get a related code. If you are concerned about failure, you could buy a new one and keep it in the truck so you have a replacement ready if/when one fails. But then, they all could last another 200k.
    blu92in99 likes this.
  18. Aug 7, 2018 at 11:13 AM
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    I learned early in the mil the value of having spares. Totally agree. :amen:
  19. Aug 7, 2018 at 12:45 PM
    Rock Miner
    Spanky
    Florida
    I've taken all your advice, I carry a spare in the box with my OBDII reader,, THANKS!
    Tnronin likes this.
  20. Dec 1, 2018 at 3:08 AM
    Jamers99
    Jamers99 Well-Known Member
    2012 Tacoma PreRunner XSP-X
    What is the part # on the Denso ignition coils for the 2012 Taco with 4.0L? My search on toyotapartsdeal.com came up with 2 different part #'s.
