Ignition contacts??
Discussion in '1st Gen. Tacomas (1995-2004)' started by ORTACO, Feb 6, 2014.
  1. Feb 6, 2014 at 2:59 PM
    ORTACO
    ORTACO [OP] Member
    06 Tacoma 4x4 TRD Offroad
    none yet
    Has any one had there's out? Working on a 99 v6 and the ignition switch is intermittent and I'm thinking the contacts are bad or just dirty. How do you get to them to check?
  2. Feb 8, 2014 at 11:37 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    take apart dash? stereo bezel comes off leading to the bezel around ignition showing ignition.
    another though, how worn is the key? ignition can also be worn. toyota SHOULD be able to cut a key if you have title in hand. however ive never asked. i know ford and a couple oems do.
  3. Feb 9, 2014 at 7:29 AM
    ORTACO
    ORTACO [OP] Member
    none yet
    It's not the key the ignition is worn this thing has 350,000 on it and it's all oem except for 1 timing belt that's all
  4. Feb 9, 2014 at 7:31 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    ok. so change it.
