Ignition cylinder replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tsalvini69, Mar 2, 2018.
  1. Mar 2, 2018 at 6:52 PM
    Tsalvini69
    Tsalvini69 [OP] Active Member
    New Mexico
    2006 4wd 4dr Black TRD
    has anyone replaced their ignition cylinder? Can I buy one that is generic or is there a certain one to get??
  2. Mar 2, 2018 at 6:54 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Are you referring to a ignition coil? If so I would trust one from Napa but not AutoZone and the like.
  3. Mar 2, 2018 at 6:55 PM
    Tsalvini69
    New Mexico
    Is that the part where the key is inserted? If so then yes. It is not a programmed key so it should just be that one part to replace?
  4. Mar 2, 2018 at 6:56 PM
    JJ Customs
    Jay
    NV
    Oh, no that the ignition switch. Again Napa.
  5. Mar 2, 2018 at 6:56 PM
    Tsalvini69
    New Mexico
    I don’t think it is a “coil”, it’s the tumbler assembly for the key....
  6. Mar 2, 2018 at 6:57 PM
    Tsalvini69
    New Mexico
    Ok so I will check with Napa tomorrow
    Have you replaced one? Doesn’t look too difficult...
  7. Mar 2, 2018 at 6:59 PM
    JJ Customs
    Jay
    NV
    I have not on a 2nd gen but I am sure you can YouTube tech it. Keep in mind you will have to re key your door locks or carry two keys if you use a key to gain entry.
  8. Mar 2, 2018 at 6:59 PM
    22argh
    22argh Well-Known Member
    not to bad to do, have a locksmith rekey it to match your doors so you don't have two different keys
    JJ Customs likes this.
  9. Mar 2, 2018 at 7:00 PM
    JJ Customs
    Jay
    NV
    Or this.
  10. Mar 2, 2018 at 7:00 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a tad tricky, the manual describes putting the old key in and turning to acc mode, then depressing a pin on the back.
    The second part is releasing the latch that clasps on after the ignition cylinder has moved partially out.
    The best thing to do is examine the new cylinder and visualize how its being held in. Then with a small pick unlatch the hook.
  11. Mar 2, 2018 at 7:03 PM
    Tsalvini69
    New Mexico
    Ya I YouTubed it, it didn’t seem to terribly difficult!
  12. Mar 2, 2018 at 7:03 PM
    Tsalvini69
    New Mexico
    Thank you, that’s what the video tech shows as well
    Bishop84[QUOTED] likes this.
  13. Mar 2, 2018 at 7:04 PM
    JJ Customs
    Jay
    NV
    You can do it. Take your time and take pictures as you go in case you forget how something goes.
  14. Mar 2, 2018 at 7:46 PM
    Tsalvini69
    New Mexico
    Ty! Great idea!
  15. Mar 2, 2018 at 11:42 PM
    Muddinfun
    Muddinfun Well-Known Member
  16. Mar 3, 2018 at 12:06 AM
    Tsalvini69
    New Mexico
