Ignition Issues After Replacing the Lock Cylinder
Discussion in '1st Gen. Tacomas (1995-2004)' started by kpihera, May 20, 2025.
  1. May 20, 2025 at 6:39 AM
    kpihera
    kpihera [OP] New Member
    2003 Tacoma Pre
    Hello,
    I was having issues with my key not coming out when turning the truck off so I replaced the original ignition lock cylinder with a new on. Now the key is coming out fine but I am experiencing a new issue that was not there before. When starting the truck I insert the key and turn it and nothing happens. I then turn the key 2-3 more times and the engine finally turns over and cranks. Could this be an issue with the new lock cylinder or possibly with the ignition switch?
    Thanks!
