ignition lock cylinder seized
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DarkMoonDisciple, Feb 23, 2025.
  1. Feb 23, 2025 at 12:51 PM
    DarkMoonDisciple
    DarkMoonDisciple [OP] Member
    Rylan
    Victoria, BC, Canada
    2007 DCLB 4x4, TRD SPORT
    2" LIFT // 18" RIMS // 33" TIRES // RUNNING BOARDS // CUSTOM GRILLE //
    Hey yall,
    My 07's ignition lock cylinder is completely locked up. It happened very unexpectedly when I was leaving work two nights ago. It had not given me any problems or signs it was failing up to this point.
    To make matters worse, I tried moving the steering wheel back and forth after spraying some graphite into the cylinder and wiggling the key in an attempt to try and get the tumblers moving and ended up locking my steering wheel (so stupid).
    So now I have a locked steering wheel that can't be unlocked because my lock cylinder is seized. To my knowledge the only way to remove a lock cylinder is by turning the key into accessory position to access a release pin. And now my steering wheel is locked in a position that covers one of the screws on the steering column cover so I can't remove that to access the tumbler/cylinder...
    I tried searching the internet and forum for advice but it all seems to pertain to the earlier generation tacomas...
    Any advice on how to tackle this issue would be greatly appreciated.
  2. Feb 24, 2025 at 11:30 AM
    Pnwadventure
    Pnwadventure Well-Known Member
    Kirkland wa
    2006 white access
    Try another key if you have one. Same thing happened to me thought it was the cylinder but turns out my key was worn out. It was my last remaining key. If you remove the passenger door cylinder it has a code on it that any locksmith can use to make you a new key.
  3. Feb 24, 2025 at 11:33 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Grab the steering wheel at 10:00 and pull that bich down as hard as you can and turn the key.
