Ignition Lock Cylinder Trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by suzuguru, Jan 10, 2023.
  1. Jan 11, 2023 at 3:32 AM
    Sfish2002
    Sfish2002 Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    I’ve worn out 2 keys and one ignition cylinder in my 03. I only have 165k on the clock but I guess I lock and unlocked the doors so many times in addition to starts that the keys wore out. My passenger door lock also gave up the ghost so I can only open that one up from the inside. I am too cheap to let a stealership gouge me for a new $600 cylinder so I understand your pain although it was only a couple hundred to replace. There have to be some inconveniences with driving a 20 year old truck but in the grand scheme of things, this one isn’t a biggie to me.
  2. Jan 11, 2023 at 7:14 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
  3. Jan 11, 2023 at 7:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Xbeaus[QUOTED] likes this.
  4. Jan 11, 2023 at 8:54 PM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    I had a similar issue and ordering a VIN cut key from the dealer. It's pretty cheap, and worth a shot before replacing any lock cylinders. I also suspect the keys are made with softer metal so they are the wear item rather than the cylinders.
  5. Jan 11, 2023 at 9:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You'll never get that at a dealer, have to go to indie for that type of flexibility and they might even be too busy.
    I used to send the housings to a locksmith shop nearby but they're backed up now. Everybody is understaffed. We are..
    Not sure what dealers are like, but shops like mine are busy and quite often straight up slammed. Sometimes I have to recommend the whole thing just so I can be sure it'll go as fast as possible. Can't risk having to redo it. It's stressful..
    I've did a few nissan ignition lock housings recently and they're all sealed up, can't even push the release and pull the cylinder out. They make you buy the whole thing
    Bivouac[QUOTED] likes this.
  6. Jan 11, 2023 at 9:28 PM
    Bivouac
    I am spoiled I am very good friends with a family of Lock Smiths.
    I even learned how simple it is to make keys from blanks .
    Then these experiences span 30 years.
    suzuguru[OP] likes this.
  7. Jan 12, 2023 at 12:00 AM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    I couldn't find the damn wafers anywhere so I bought cheap ebay locks so I could steal the wafers and rekey to match my ignition. I think I'm in it for like $60 for a new cylinder and door locks.
    suzuguru[OP] and Xbeaus like this.
  8. Jan 12, 2023 at 10:13 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Whoa! Why the sarcasm? The guy was just making a comment.
    Bivouac and Xbeaus like this.
  9. Jan 24, 2023 at 5:20 PM
    suzuguru
    suzuguru [OP] Well-Known Member
    Eric
    Nashville, TN
    2001 Tacoma 4WD, 1996 Land Cruiser HDJ80, 1985 Pickup 4WD
    It was perfect for about 2 weeks, then it started doing it again. This time, I removed the ignition cylinder, disassembled it, and removed the 2 split wafers. They were numbers 4 and 7 going from the front to rear. Seems to have fixed the problem, but only time will tell. I'm not too worried about someone picking the ignition lock.
    Xbeaus likes this.
  10. Jan 24, 2023 at 5:21 PM
    suzuguru
    Eric
    Nashville, TN
    When you make a comment on someone else's thread insinuating that they're an idiot.... then you get sarcasm.
  11. Jan 26, 2023 at 8:12 AM
    skeezix
    Colorado
    1998 Limited
    I didn't imply or insinuate anything. You inferred that I called him an idiot. One can infer whatever one wants.
  12. Jan 26, 2023 at 8:52 AM
    suzuguru
    Eric
    Nashville, TN
    If you don't like it, there's a little button that says "ignore". Feel free to use it.
