Ignition Lock Cylinder
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reverse_Sear, Oct 9, 2021.
  1. Oct 9, 2021 at 5:19 PM
    Reverse_Sear
    Reverse_Sear [OP] Member
    Christopher
    97 Tacoma 3.4L 5VZ-FE 4x4
    Hi, I have a 1997 Tacoma 4x4.
    Last week it was broken into and the ignition lock was hacked up with a screwdriver. Luckily for me my truck wasn't stolen!!
    I'm trying to take the ignition lock out. I've drilled out the button underneath the cylinder and I can move the the cylinder out about a 1/4" of an inch but that's as far as it will go. I'm using a lot of muscle with no success. With a screwdriver, I'm also able to move the ignition around from lock to start.
    Any ideas?
  2. Oct 9, 2021 at 5:27 PM
    Reverse_Sear
    Christopher
    I wish that would have worked. The key hole was really banged up and only started turning after the drilling. I'm guessing that's why it wasn't stolen:)
    whatstcp likes this.
  3. Oct 9, 2021 at 7:07 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Even though the lock cylinder is Fubared
    You might need to drill out the whole lock cylinder because of damage keeping it from coming out.
    How did you keep the pin from spinning did you have a helper? We use one to hold the pin the other to drill
    Your sure you have enough of the pin drilled out?
  4. Oct 9, 2021 at 8:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure if Toyota's are the same or similar but I had to do a Ford Focus one time that had a worn out lock cylinder that wouldn't turn anymore, the instructions in the service manual were to drill to the side of the keyway where the lockbar was and extract it to allow the cylinder to turn.
    I can't find anything on a Tacoma lock cylinder, a locksmith probably would know where to drill but most probably aren't going to tell you.
  5. Oct 11, 2021 at 4:50 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It sucks but you have to keep going with the drill until it comes out. If the housing gets (or already was) damaged you'll have to replace it too
  6. Oct 11, 2021 at 1:46 PM
    Glamisman
    Glamisman Well-Known Member
    Many thoughts come to mind… if the ignition lock cylinder housing is reusable and you can get a new lock cylinder ask if the replacement lock cylinder can be rekeyed. Many can’t and it is a pain to remember this key for the door and this key to start it… the other bit of good news is that the airbag key is the ignition key.
    Replacing the lock cylinder housing is either a big job or easy, depending on your toolbox and your experience. I have been very successful in using a very sharp small chisel and striking the sheer bolt head 90 degrees on the rim creating a raised portion then angling the chisel and with a few taps, loosening the sheer bolt. In some cases I will have to center punch the sheer bolt and using a left hand drill bit drill the sheer bolt out and somewhere during the drilling process it unscrews the bolt. Once one is loose the other will come out easy.
