Ignition lock
Discussion in '1st Gen. Tacomas (1995-2004)' started by RobbD, Feb 9, 2020.
  1. Feb 9, 2020 at 9:48 AM
    RobbD
    RobbD [OP] Member
    Robert
    1998 Tacoma SR5 4x4
    None
    My 1998 Taco recently starting doing this. Turn the key starts normally then turn the key nothing. Battery and alternator operating normal, starter same. The last time key got stuck and wouldn’t come out. Got the truck towed home cramped right up. I think I need a new ignition. Anybody have the same problem?
  2. Feb 10, 2020 at 5:15 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Yes. it usually occurs when someone has a heavy key ring with a lot of keys on it. Toyota will tell you to only put the ignition key in there, but most people just put their key on with all their other keys, resulting in the ignition key cylinder needing to be replaced. This is not expensive. But, there are two kinds of ignition cylinders out there, those that come with their own set of keys, and those that come with KEYABLE ignition. The Keyable one is usually only about $30 more, but well worth it to me, because you can then have it keyed to match the original key so that all keys and locks are the same, as was how they came. Otherwise, you would have to carry a key for the ignition as well as one for the doors. Fords are or used to be, like this, but to me, it makes no sense. In any case, I had to replace my ignition cylinder once when the same thing you are describing happened to me. On my wifes 96 RAV4, she has had to replace her ignition cylinder twice for the same thing. THe cylinder that is keyable was running around $180, give or take, with most average mechanics charging around $100 or so to replace it for you.
  3. Feb 10, 2020 at 7:12 AM
    Glamisman
    Glamisman Well-Known Member
    sounds like 2 seperate but interconnected issues. Replacing the ignition lock cylinder is a pretty easy job and as mentioned above get one that is re-keyable otherwise you end up with multiple keys for the same truck. Behind the ignition lock cylinder is the electrical portion of the ignition switch. While these do fail it isnt that common. If after you have replaced the ignition lock cylinder you still have cranking issues then further investigation is warranted. This is an easy job... on a 1 to 10 scale it is a 1, if you have a few screwdrivers.
    Black DOG Lila likes this.
  4. Feb 19, 2020 at 1:46 PM
    Woodcutter
    Woodcutter Well-Known Member
    Missouri
    3.4L V6 96 Taco 4 x 4 SR5
    I would like to know the purchase source for a Keyable lock cylinder. Thanks! Woodcutter
