ignition locked up
Discussion in 'Technical Chat' started by ray parnell, Aug 1, 2010.
  1. Aug 1, 2010 at 12:11 PM
    ray parnell
    ray parnell [OP] New Member
    94 tacoma lowered
    My sons 94 tacoma's ignition locked up. I cant even get it to go to acc to release the steering, any suggestions
  2. Aug 1, 2010 at 1:17 PM
    bambam
    bambam Active Member
    David
    Louisville Ky
    put the key in and smack the back of the key with the rubber end of a screwdriver while u turn the key, worked for me
  3. Aug 1, 2010 at 1:43 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    I had the same problem before with a different toyota. There is something worn or cracked inside the ignition. Its another safety mechanism besides the electronic chip found inside of the key. I thought the computer wasnt recognizing the key. Not the case at all. after spending about $200 dollars on a replacement that didnt work and 2 days at the stealership, I only needed to remove the ignition and take it to a locksmith to repair it which cost me a mere $25 dollars. U can get it fixed by toyota for about $200. Hope this helps.
    G
    Let me know if u have a question about igniton removal. And Welcome to TW!!
  4. Aug 1, 2010 at 1:47 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    turn the steering wheel hard left and try to turn the key, if that doesnt work, turn it hard right
  5. Aug 1, 2010 at 3:02 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Yep this is what happens to me when the wheel gets turned with no key. You just have to get it in the center of the farthest you can go each way.
  6. Aug 1, 2010 at 4:13 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Just throwing something out there -- how about a drop of oil. It's worked for me on door locks and a
    Motorcycle ignition
    Just an idea
  7. Aug 2, 2010 at 2:20 PM
    ray parnell
    94 tacoma lowered
    Thanks for comments but none would work. If i could just get it to the acc position i could pull the ignition but it won't turn at all. I guess i might have to call the stealership
  8. Aug 2, 2010 at 2:41 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I had this problem with my '85 K5. The ignition was worn out so I had it replaced.
    A friend of mine was locked out of her car because her door lock/key was worn (the only lock on a Trailblazer is on the driver's door), so I sprayed just a bit of WD-40 on the key and inside the key cylinder and, SHIZAM! It worked like a charm.
  9. Aug 2, 2010 at 6:18 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    WD-40 or pretty much any other oil type lubricant does work great, but is not a good practice for lock mechanisms because they attract dirt which over time will make the problem even worse. There are non-dirt-attracting lubricants made specifically for locks, maybe ask at a locksmith shop, or use powdered graphite, comes in little tubes at any auto parts store. Might even find the lock type specific lubes there also, I don't know about that. I use graphite inside locks.
  10. Mar 29, 2011 at 6:56 AM
    MikeP
    MikeP Member
    Western Washington
    2002 4x4 TRD
    The ignition on my 2002 Toyota Tacoma 4x4 TRD locked up after I parked with the left front wheel pushed against a curb (vehicle at 40 degree angle to the curb). When I got ready to leave the Fed Ex place I had parked at, the key would not turn in the ignition. The steering wheel was locked up tight and would not budge.
    I had to use my jack to raise the left front wheel until it no longer was pinched against the curb and this apparently relieved the pressure on the front left wheel as I was then able to turn the steering wheel a little and then I could turn the key (rotate right) in the ignition so the engine started. What a bummer.
    I had phoned the local nearby Toyota Dealership and they advised me to pull hard on the steering wheel but I could not budge it. The service guy at the Dealership said if that did not work I would probably have to have a tow truck come and pull my Toyota away from the curb to get that pinched left wheel away from the curb. The service guy did not tell me about using a jack to raise the pinched wheel. A clerk at a nearby Fred Meyer advised me about using the jack to raise my Toyota. I had just driven from Kelso to Seattle when this happened on 3/28/2011. It took me about 3 hours of messing around to get this situation resolved.
  11. Mar 29, 2011 at 6:30 PM
    radioactivemint
    radioactivemint Well-Known Member
    Oregon
    2011 Reg. Cab 4x4
    That's actually really good to know. Thanks, Mike.
  12. Apr 16, 2011 at 3:14 PM
    pcrocker
    pcrocker New Member
    forrest city, AR
    2001 4wd
    Ignition lock hangs when trying to start. Will eventually start when key is repeatedly placed and removed from the lock. This ignition has had this malfunction ever since vehicle was purchased new.
