ignition on OR off when bleeding brakes on 2006 TRD Sport??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, May 25, 2019.
  1. May 25, 2019 at 12:09 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    New rear axle is installed, now just fighting with bleeding the brakes. Are you supposed to have the ignition on when bleeding the brakes or off? I can't remember.
    Thanks
  2. May 25, 2019 at 1:35 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Doesn't matter unless you have the ATRAC/VSC electronic master cylinder, with the ABS pump built into it, which I don't imagine you do. Engine off (and there's no reason to have the ignition on) makes it a lot easier to feel a firm pedal than the engine running and the booster working.
  3. May 25, 2019 at 1:49 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
  4. May 25, 2019 at 2:53 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    OFF - cause if you lose pressure believe the ABS module will lock you out/up.
