Ignition power
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma TP, Mar 2, 2021.
  1. Mar 2, 2021 at 3:04 PM
    Tacoma TP
    Tacoma TP [OP] New Member
    Todd
    2016 tacoma TRD Sport White
    Lift -3" front 2"rear, BA front bumper w/ 20" light bar, replika TRD wheels +5 offset, Falken Wildpeak A/T III 275/70/17
    Hi, I am new to this forum a curious if anyone knows of a good location to access ignition power to switch a light bar?
  2. Mar 2, 2021 at 3:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Hi, T. Welcome to TW!
    Junkhead and tcjacado like this.
  3. Mar 2, 2021 at 3:05 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
    Junkhead likes this.
  4. Mar 2, 2021 at 3:08 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    get an add a fuse and tap into a fuse that is ignition-based. There are several you can choose from.
  5. Mar 2, 2021 at 3:28 PM
    Tacoma TP
    Todd
    I did order some “add a fuse” today, however it doesn’t look like i will be able to put the cover back on if i use these. Thanks
  6. Mar 2, 2021 at 7:16 PM
    nudavinci64
    Robert
    @MESO used to sell a taller cover. on second gens we have no cover.
  7. Mar 2, 2021 at 7:19 PM
    desert_gypsy
    desert_gypsy Well-Known Member
    2020 MGM TRD Off-Road
    You want your light bar to be on when the ignition is on?
  8. Mar 2, 2021 at 7:21 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You can open the clip on the wire bundle going into the box and thread your aaf cable through
  9. Mar 2, 2021 at 7:24 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Welcome to TW.
    I'm going to start with the assumed/unassumed knowledge.
    You do know to power the light bar with a relay, right?
    Power the relay from the battery terminal, then power the switch from inside your cab. The fuse marked "p outlet no. 2" is a good one for your switch if you want it only on during ignition.
    If you need a diagram there are multiple threads around here that have one. I might have one too, if you need.
    Have fun.
    tcjacado likes this.
  10. Mar 2, 2021 at 7:58 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    He still does and they're in stock. Put one on mine recently for future add a fuse activities. It even has punch outs on the side for the wires. And it's far easier to take off. Completely worth it.
    Doc62, MESO and nudavinci64[QUOTED] like this.
  11. Mar 2, 2021 at 8:10 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I broke the factory cover on mine the first time I popped it off. Might as well accept the inevitable, because it doesn't take much. Lol
  12. Mar 2, 2021 at 8:27 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    :bowdown::bowdown:
    Doc62 and nudavinci64 like this.
  13. Mar 3, 2021 at 3:37 PM
    Tacoma TP
    Todd
    Thank you everyone, i wired up the switch today with a add a fuse from CT, i will need to order the extended cover from MESO, yes, i wired up a relay, this power was for the switch power only. Thanks again.
    Rock Lobster likes this.
